Performance Clutch/Flywheel Anyone?
Old Jan 10, 2018 | 07:05 PM
SinF's Avatar
Originally Posted by Unhingd
Jag has done this probably to prevent numbskulls from shock loading the drive train by lifting suddenly without depressing the clutch.
Modern cars should be able to withstand this. This is also why engine mounts provide both compression and decompression resistance. If drive train cannot survive high RPM transition from WOT to closed throttle, then it is not adequately hardened.
Old Jan 10, 2018 | 10:01 PM
Unhingd's Avatar
I agree with you, but Jag appears to be using the computer to compensate for an under engineered driveline.
Old Jan 11, 2018 | 02:26 PM
approx's Avatar
I didn't take this feature as making up for an inadequate driveline, it's more of a comfort feature. If someone isn't used to driving a manual, keeping it at the correct RPM for the next gear for half a second makes the shift up go more smoothly.
Old Jan 11, 2018 | 02:32 PM
SinF's Avatar
Just to make sure we don't create confusion with this discussion. F-type DOES NOT offer rev-matching functionality.
Old Jan 11, 2018 | 02:41 PM
approx's Avatar
Ok now I AM confused! What do you call what it has then? When I put in the clutch, it'll automatically hold for a half second at the RPM of the next gear. Is that not rev-matching?
Old Jan 11, 2018 | 02:45 PM
DJS's Avatar
DJS
Jaguar claims that the automatic does. At least, in this document, under 'Dynamic Launch', they imply that all that dynamic launch does is not do rev matching, for more violent shifts. If you believe it.
https://www.dropbox.com/s/wskjex70o2...ntrol.pdf?dl=0
Old Jan 11, 2018 | 07:11 PM
SinF's Avatar
What year is your car?
Old Jan 11, 2018 | 08:13 PM
  #28
Unhingd's Avatar
I call it a 60 pound flywheel.
Old Jan 16, 2018 | 04:14 PM
approx's Avatar
2016
No, it very specifically and intentionally hangs at a very specific RPM for a portion of a second. I'll take a video next time I'm in the car since neither of you seem to believe me!
Old Jan 16, 2018 | 07:17 PM
  #30
Unhingd's Avatar
2016
If this were done for the purpose of rev matching on the up shift, they would have allowed the rpm to drop a few hundred rpm before causing it to hang.
Old Jan 16, 2018 | 11:46 PM
  #31
lizzardo's Avatar
I agree, and since that's not what it does, I don't think that's why it's doing it. It's repeatable and consistent enough that I've adapted to not have it happen. I'll have to deliberately try to induce it now to see if the VAP tune has eliminated it.
Old Jan 17, 2018 | 06:47 AM
  #32
caviarjag's Avatar
That's what my 2017 seems to do. But it could all be in my head.
Old Jan 17, 2018 | 08:12 AM
  #33
Unhingd's Avatar
Could well be. I never hesitated long enough between upshifts to notice this phenomenon, and on downshifting I take matters into my own feet with an extra clutch pedal pump.
Old Jan 17, 2018 | 11:07 AM
  #34
approx's Avatar
That's exactly what it does! If I wait, it drops the rpm to where it needs to be for the next gear, holds it there for a bit, and if I don't shift in time, then it drops it all the way to idle.
Old Jan 27, 2018 | 01:51 AM
  #35
approx's Avatar
Took a while, but here's the video proof...!
Old Jan 27, 2018 | 05:28 AM
  #36
Unhingd's Avatar
I never noticed that. Does that hang always occur at around 2700rpm or does it depend on the rpm at which the shift is initiated?
Old Jan 27, 2018 | 12:56 PM
  #37
Unhingd's Avatar
If so, maybe VAP can eliminate the effect. Jag has done this probably to prevent numbskulls from shock loading the drive train by lifting suddenly without depressing the clutch.
No need to eliminate the effect. I played with it today. It does indeed hang for a second at an engine speed based on the road speed and next higher gear. The reason I never noticed it is that I typically complete an upshift in half the time it takes for the engine to slow down to that hang point. However, there may be some real value to having that hang point when the lightened flywheel is installed. One of the challenges of driving a lightened flywheel would already be addressed.
BTW, the clutch/flywheel builder will have the parts to measure by next Wednesday. The OEM clutch is 18 lbs and the flywheel is 38 lbs.
Old Jan 29, 2018 | 10:59 AM
  #38
approx's Avatar
Beyond quick shifting, it's also hidden by shifting at a higher RPM. It seems the "timer" for it starts when the clutch is depressed, not when the engine reaches the specific RPMs for the next shift. Shifting at higher RPM's (where there is more RPM spread between gears) means the engine may not have time to reach the hang point before the timer runs out and it won't hang at all. In my video, you can see that it holds for a very short time on the first shift for that reason.
Back on topic - this is an exciting project! I will definitely be interested in a lightened clutch/flywheel when the time comes for replacement.
Old Jan 29, 2018 | 03:55 PM
  #39
caviarjag's Avatar
Good to know I am not crazy. I only ever noticed when driving around town and making gentle shifts or running out first and second, letting up and then skip shifting right into fourth. You definitely wouldn't notice if you are on the car all the time.
Old Jan 29, 2018 | 07:30 PM
  #40
Unhingd's Avatar
yeah...that’s me.
