Picking Up 2016 F-Type S - What to look for?
Old Oct 17, 2018 | 06:50 AM
Leddo's Avatar
Default Picking Up 2016 F-Type S - What to look for?
Hey, first time F-Type owner (moving from an XF Sport).
i bought a 2016 F-Type S and picking it up on Friday. Any tips on what to check for, or make sure the dealer has done before hand?
i asked him to ensure the entertainment software has been updated. Anything else?
Thanks.
Old Oct 17, 2018 | 07:22 AM
planet_FType's Avatar
Check the oil level to ensure you don't have Oil Overfill. Easy to fix at the dealers but a PITA if discovered later.
Old Oct 17, 2018 | 08:10 AM
uncheel's Avatar
Get a service history, if you haven't already, to see if the maintenance is current, including the last oil change, and see if there have been any recurring problems.
Checking the oil level is always a good idea, especially on a used vehicle, although it has not been common problem. (warm engine, let car sit 10 minutes, ignition on but not running, vehicle information from menu - see manual). You aren't as likely to have the overfill situation that was mentioned above on the V-6. (There was a error in some of the early V-8 documentation, so there is some history of dealer overfills.)
Check the tires to make sure you're happy with their condition/wear. Aside from alignment, the original P-Zeros wear quickly. There are a lot of Michelin 4S fans on the forum, myself included.
Meanwhile, check out the sticky section on the forum, especially the "How To" and "Known Problems" threads.
For entertainment value, run through the "Any funny bystander reactions" thread to prepare yourself. It's a car that garners attention (mostly for the good):
https://www.jaguarforums.com/forum/f...-share-147352/
Old Oct 18, 2018 | 12:10 PM
Leddo's Avatar
Thanks for the tips!
Jeh
Aug 16, 2015 06:20 PM
Ben1400
Oct 20, 2013 05:01 AM
FrankB2
28
Oct 11, 2012 01:51 PM
swoop22
Oct 19, 2011 10:43 PM
