question about tire pressure monitor
Old Jun 11, 2016 | 10:24 AM
Frenchy's Avatar
Default question about tire pressure monitor
It seems to work. I'm running 39psi cold and it rises to 41 when the tires warm up.
My question is about the (...) under each of the 4 numbers. What's that?
Old Jun 11, 2016 | 10:36 AM
Arne's Avatar
On mine it says (36) under each, which is the recommended tire pressure. I am usually running a bit higher than that (39-40).
Old Jun 11, 2016 | 11:20 AM
Unhingd's Avatar
Interesting. Mine recommends 37psi
Old Jun 11, 2016 | 11:49 AM
Nati's Avatar
Same. Mine sit at 39 cold I just haven't gotten around to letting a few pounds out. This was from the factory...
Old Jun 11, 2016 | 11:57 AM
Arne's Avatar
Maybe my memory is off.... I will have another look next time out driving.
Old Jun 11, 2016 | 11:58 AM
Frenchy's Avatar
That might be the fastest highjack in internet history.
Guys, my question wasn't about the correct tire pressure. I'd like to know why, UNDER each of the 4 numbers indicating the current pressure for each tire, there are 3 periods in parentheses, like this: (...)
It's not explained in the manual.
Thanks.
Old Jun 11, 2016 | 12:10 PM
Nati's Avatar
Hmm. We are telling you that we don't have periods in the parentheses. We have numbers.
I wonder if the dealer needs to set the recommended pressure value in your computer.
Old Jun 11, 2016 | 01:02 PM
Arne's Avatar
Maybe my
Just checked now, and my recommend tire pressure is 36 psi.
Not shure why it is different? Mine are on 20". Maybe 19" and/or 18" are different, or do you have 20 as well?
Old Jun 11, 2016 | 01:21 PM
Unhingd's Avatar
Quite possibly. I'm currently on 20s, but the car was delivered with 19s.
Frenchy, drive the car for a few miles and see if the parens get populated with some numbers.
Old Jun 11, 2016 | 02:15 PM
lsbrodsky's Avatar
No, my 20's recommend 37 on the display and the door tag.
Larry
Old Jun 11, 2016 | 04:00 PM
Unhingd's Avatar
Larry
Then it's still a mystery why Arne's display is specifying 36.
Old Jun 11, 2016 | 05:02 PM
ShaunPA's Avatar
Mine is also 36
Old Jun 11, 2016 | 09:38 PM
Mbourne's Avatar
Originally Posted by ShaunPA
Mine is also 36
My door notice says 36. I haven't found the pressure sensor display yet. How do I get to it?
Old Jun 12, 2016 | 01:53 AM
Arne's Avatar
You have to turn ignition on without starting the engine. Use the "ok" button and directional buttons to the left on the steering wheel to manouver in the display menu. I don't remember exactly what it is called, but it is something like "car information" menu and then "tire pressure".
Old Jun 12, 2016 | 05:56 AM
Unhingd's Avatar
Follow Arne's instructions: push ignition button with your foot off brake pedal, and push menu/ok button.
Then: push the up or down arrow until you get to "vehicle information" screen between the gauges. push ok button again, and then scroll down to "tire pressure" and hit the ok button again.
Hint: the left arrow reverts you to the previous screen.
Old Jun 12, 2016 | 06:25 AM
DJS's Avatar
DJS
2014s don't display the pressure, unfortunately.
Unhingd's Avatar
New theory: All the my14 and my15 models are set at 36. All the my16 and my17 models are set at 37.
New mystery: In the "vehicle info" screen, there is a "tire info" option (not talking about "tire pressure" option). In the "tire info" option you can select either display units or "recommended tire pressures".
Selecting the latter produces the following results:
................. Front ...... Rear
slow speed ... 37 ......... 37
normal ......... 45 ......... 41
The "normal" values seem to me to be appropriate values for roadtrack applications, but there has been a lot of discussion by some that higher values are inappropriate for new tire technology. I refrained from argumentation as I had no definitive proof to the contrary, but this seems to support my thinking that tire pressures need to be elevated for high speed handling purposes.
Old Jun 12, 2016 | 09:08 PM
Mbourne's Avatar
Nope. The 14S does not have that option in "vehicle info". Only have Oil Level, Vin Display, AHB sensitivity and one other thing I can't remember. None of the other menus has it either. Guess I just need to continue my periodic checks the old fashioned way.
Old Jun 13, 2016 | 05:06 AM
Arne's Avatar
I see that in the F-type owners handbook from 2013 it says:
Tyre pressures - up to 250 km/h (155 mph): Front 36 psi / rear 36 psi (20")
Tyre pressures - over 250 km/h (155 mph): Front 41 psi / rear 41 psi (20")
It also says: "Vehicles supplied with 20 inch wheels also have a speed based TPMS system. If the vehicle is required to travel at speeds over 250 km/h,the tyre pressures should be raised. Failure to do this may cause the warning message TYRE PRESSURE LOW FOR SPEED to be displayed in the Message centre.
Old Jun 13, 2016 | 08:46 PM
Mbourne's Avatar
Did not know that thanks. I've kept mine at 36. Well then I'm glad Rickjay only made me go 150 on the Lobster Run
