Rear Fog Lights not working
Old Jan 3, 2017 | 12:32 AM
Totti's Avatar
Default Rear Fog Lights not working
Hi all,
It was quite foggy this morning and I wanted to use my rear fog lights. However, when I pressed the button nothing happened, the fog light icon did not illuminate in the dashboard and the rear fog lights didn't work.
Did anyone else face the same issue?
Old Jan 3, 2017 | 01:41 AM
OzXFR's Avatar
Did you have your headlights turned on?
The fog lights only work with the headlights on.
Old Jan 3, 2017 | 02:49 AM
Totti's Avatar
Hi OzXFR,
The headlights were on Auto setting.
Old Jan 3, 2017 | 03:11 AM
OzXFR's Avatar
Originally Posted by Totti
Hi OzXFR,
Which means the fog lamps should work, so I'm stumped!
Old Jan 3, 2017 | 03:36 AM
TwiztOG43's Avatar
it only works when its somewhat dark outside. For example, when I try to activate it in the middle of the day outside, it doesn't work at all. however, in the parking garage it turns on.
Old Jan 3, 2017 | 04:25 AM
OzXFR's Avatar
So maybe it's what I first thought, that the headlights (or the parkers) have to be actually on (shining), even though the Owner's Manual says they should work as long as the headlights, parkers or "auto" are on.
Old Jan 3, 2017 | 05:18 AM
Arne's Avatar
I think your assumption is correct.
Old Jan 3, 2017 | 06:53 AM
Unhingd's Avatar
My understanding is that the headlamps have to actually be lighted for the fog lights to works. Therefore, if in Auto-mode. it has to be dark enough for the headlamps to fire up before the fogs are functional. Gotta turn the lights to "on" if you want fogs during the day.
Old Jan 3, 2017 | 07:55 AM
Totti's Avatar
You are right. I took my car to an underground parking and the fog lights worked fine.
Tomorrow I will try to manually switch the front lights on then switch on the fog lights, but I think it should work fine.
Thanks all for the help.
Old Jan 3, 2017 | 08:37 AM
xdave's Avatar
As has been found, that instruction has to be taken "literally". i.e. the headlamps, parking lamps or auto lamps need to be on and not just selected. Most (maybe all?) cars are like that.
When driving in fog you should always select manual lights and not rely on the auto settings else it usually means you'll be driving along in fog with no external lamps on. The sensors are not clever enough to look at the actual road visibility yet, and daytime fog is nice and bright!
Old Jan 3, 2017 | 05:48 PM
Mbourne's Avatar
Also is every car I have owned the fogs automatically turn off the moment the high beams are on.
Old Jan 3, 2017 | 05:59 PM
OzXFR's Avatar
I think that might be front fogs (which the F-Type doesn't have), we are talking rear fogs here.
