rear spoiler alignment
Old Oct 8, 2019 | 04:32 PM
powerhouse's Avatar
Default rear spoiler alignment
ok talk about jaguar panel alignment, how do i sort this, I know how to adjust the spoiler from closing to much but how do I sort this side alignment as per arrows, big difference from one side to another
Old Oct 8, 2019 | 07:05 PM
OzXFR's Avatar
You need to loosen off the four spoiler mounting bolts from underneath (two each side) then nudge the spoiler over a gnat's wotsit until it lines up nice and even.
Don't loosen the bolts right off, just enough so you can move the spoiler but it is still held reasonably firm.
You will probably need a bit of trial and error which means lowering the hatch after each adjustment and checking the fit/alignment and then doing some more nudging and checking until you are happy it is perfect, then do the four bolts up good and tight.
The bolts are under the two oval shaped plugs on the underside of the hatch, you need to "untuck" the rubber surrounds on them (I used a trim removal tool) then you can flip the plugs out (again I used a trim removal tool).
Old Oct 10, 2019 | 07:01 AM
powerhouse's Avatar
thanks OzXFR for the tip on the spoiler, sorted, I loosened out the two rubbers that adjust the hatch closing , can’t adjust them anymore or they’ll fall out. , still not flush any suggestions for that
Old Oct 10, 2019 | 07:46 AM
OzXFR's Avatar
It looks like your spoiler needs to come up around 1 mm on the LHS and about 2 mm on the RHS.
I had the same problem on the LHS, it was about 2 mm low, while the RHS was pretty good.
I found that screwing out the rubber/spring made very little difference, so I tried something else and it worked.
I raised the LHS by pulling out the round "plug" or stopper on the inside of the hatch that the rubber/spring butts up against (just use a trim clip puller tool), putting three maybe four layers of Velcro (the smooth side) on the underside of the plug - punch a hole in the middle of each piece, stick it on the plug over the "prong" then trim the excess off with scissors - then push/tap the plug back in place.
I found that after a few days the spoiler dropped a little again, maybe a mm, I guess due to the Velcro being compressed, so I whacked another piece on the plug and that fixed it permanently.
If that doesn't work for you there is one more thing you can try - remove the rearmost spoiler mounting bolt and slide one or two 1 mm thick washers between the mounting bracket and the spoiler lid (ie so the washer is packing out the lid), then refit the bolt. The problem with this method is that it may raise the spoiler lid up too high at the window end so that it ends up sticking up above the level of the surrounding panel, but worth a try if all else fails.
Old Oct 10, 2019 | 09:11 AM
powerhouse's Avatar
Just did the velcro trick, brilliant everything sorted, cheers
Old Oct 10, 2019 | 07:23 PM
OzXFR's Avatar
Glad to be of service!
From what I see in pics on here of the rear end of the coupe almost every single F-Type suffers from poor alignment of the spoiler but it's an easy fix.
Old Oct 14, 2019 | 05:48 PM
OzXFR's Avatar
Update, mainly for peppersam740 who pm'ed me about this.
Going from memory now but I think I left out a vital step!
I'm not entirely sure but I *think* those four spoiler mounting bolts are covered by little plastic clip-on covers.
You have to raise the spoiler first and remove those covers before you can access the mounting bolts from underneath.
The covers push off real easy, from inside to outside IIRC.
If I'm right that should mean that you can adjust the fit of the spoiler by doing it this way, ie with the spoiler up, which would be much easier than doing it via the plastic plugs on the underside of the hatch. Or maybe the spoiler doesn't open far enough to allow decent access to the bolts, I dunno.
But I do remember that I had to do it via the underneath plugs coz I wasn't looking to align the spoiler, instead this was the method for permanently disabling the spoiler in the "down" position, and you can't access those mounting bolts any other way if the spoiler is in the down position.
dianebauman
Sep 14, 2023 06:04 PM
powerhouse
Aug 30, 2019 03:44 PM
Apparent
Aug 31, 2017 12:34 AM
jfranks
Apr 8, 2017 03:39 PM
Datsports
Jun 7, 2016 04:20 PM
