Rear Spring Isolators Sleeves?
Old Nov 19, 2020 | 05:25 AM
V6S_JM's Avatar
Default Rear Spring Isolators Sleeves?
Hi guys,
My dealer has called and advised they've tracked down the slight rear clunking sound. Apparently it needs 2x "Spring Isolator Sleeves" fitted. Not sure if they're just missing or perished... Car is one of the first 2013 V6S.
Did this fix your issue? (assuming you've experienced it)
Does anyone have the part number for these? Is it T2R15835 ?
I'm considering fitting lowering springs in the near future, so seems little point in going ahead with this repair and removing the springs twice... Also I assume they'll be required with Eibachs or the likes? Or are the coils a different thickness?
Old Nov 19, 2020 | 07:29 AM
DJS's Avatar
DJS
Yes, that was one of the first TSBs. Happily, my car never developed that.
Old Nov 19, 2020 | 05:25 PM
Unhingd's Avatar
Any spring configuration will require those isolators to avoid suspension noise.
Old Nov 19, 2020 | 10:46 PM
bjg625's Avatar
I have early '14 (# 1100) and remember the clunk issue in the forum but never had it on my low mileage car.
Old Nov 20, 2020 | 09:50 AM
NJ68's Avatar
I have a 2014 v6s and had the replaced around 12,000 miles... I say replace but it was required... the original ones deteriorated / pieces broke apart.. show them on the garage floor. They have been fine since replacement.
Vee
Mar 22, 2021 01:55 AM
Yellow series3
Aug 11, 2019 03:15 PM
petemohr
Mar 16, 2016 07:06 PM
felinecat
E type ( XK-E )
Jul 31, 2015 01:43 PM
etaent
Jan 29, 2012 12:34 AM
