Is this the rear tow hook?
Old Dec 28, 2018 | 07:42 AM
DJS's Avatar
DJS
Originally Posted by scm
My MY18 manual says "Only tow the vehicle in a forward direction with all four wheels on the ground. Towing in a reverse direction or with only two wheels on the ground will cause serious damage to the transmission."
Maybe this applies only to later AWD models?
No, that’s for all F-types, as far as I know. The rear hook is only used during shipping.
Old Dec 29, 2018 | 06:36 AM
Unhingd's Avatar
Originally Posted by Jaggyx
Anyone know how to remove the rear tow cover and if they are the same between both V6 and V8 diffusers?
I tried to reach my hand back there, but it seems quite stuck and not sure I want to break anything should I be pushing incorrectly.
The V6 and V8 rear tow hook covers are different shapes. A narrow spackling knife can be safely used to pry the cover from the bumper face. That tow location should never be used with an AT.
Old Dec 29, 2018 | 05:00 PM
Jaggyx's Avatar
Thanks for confirming. I'm switching over to the OE quad diffuser and wasn't sure if I needed to order a new piece as well... About $90 shipped for that dang thing, but I did end up ordering.
Old Sep 17, 2023 | 05:04 PM
Marlow42's Avatar
If you still have it, I'll buy it... Or not best ask for measurements of reverse thread...!
I'm stuck on wet grass, front is two feet from wall and pointing slightly down. Rear tires are less than two feet from the road but still couldn't reverse onto it. Wheels spinning even after trying mates, boards, etc. Therefore, need slight help from rear toe hook/tie down under power to get onto the road...
Old Sep 17, 2023 | 06:46 PM
GeorgeIII's Avatar
As stated here, in the manual and elsewhere, the black rear tow hook is not for towing. It is used as a tie down during shipment.
Old Sep 17, 2023 | 07:54 PM
uncheel's Avatar
It's really a question of how much pull you want from that end. If it's just to get traction aid for a couple of feet, you're probably OK as long as you take it easy on the initial engagement.
Old Sep 18, 2023 | 04:30 AM
Marlow42's Avatar
Basically, it's literally less than two feet and even then I'm thinking of finding a proper cast iron or steel version/copy locally from an auto shop or somewhere
Old Sep 18, 2023 | 07:39 AM
  #28
DJS's Avatar
DJS
If I come across mine, you can have it. Not sure where it is.
Old Sep 19, 2023 | 12:28 PM
Michael211's Avatar
I was told that towing using the rear hook is likely to bend the frame member it screws into due to the angle. It angles down because it is a shipping tie down anchor point. Pulling on it parallel to the ground would create torque on the anchor point. Makes sense to me.
Old Sep 19, 2023 | 12:57 PM
  #30
GeorgeIII's Avatar
Makes sense to me also which is why the manual say's don't do it.
Old Sep 19, 2023 | 07:51 PM
  #31
lizzardo's Avatar
That's what I've heard too, and having looked at the place it threads in I'm sure that's the case.
Old Sep 19, 2023 | 11:01 PM
  #32
wetwolf's Avatar
Does it look like this: https://www.ebay.com/itm/15556984855...3ABFBMgOX1i9Zi
There was one of these in my trunk too. Funny that we have an Aston Martin towhook that we should not use...
Old Sep 20, 2023 | 01:25 AM
  #33
OzXFR's Avatar
Yep it looks just like that pic.
Old Mar 1, 2025 | 10:06 AM
  #34
J444G's Avatar
Anyone tried to actually remove the hook cover from V6? I tried all my pry tools without success... I am a bit embarrassed that this defeated me lol.
Old Mar 1, 2025 | 10:31 AM
  #35
DJS's Avatar
DJS
I’ve removed the front cover many times, it comes off easily. Haven’t had any reason to remove the rear cover.
Old Mar 1, 2025 | 12:31 PM
  #36
Michael211's Avatar
Be careful. You can't tow with it, and it seems to be useless for anything but a tie down while shipping, and only then if chain or strap you use follows the angle of the bolt hole in the frame.
Old Mar 1, 2025 | 01:24 PM
  #37
J444G's Avatar
I have bought a design pack diffuser and I need the cover to switch to the new one
Old Mar 1, 2025 | 02:09 PM
  #38
lizzardo's Avatar
Mine is in storage since so I can't easily check, but as I recall, you can see the back of it from underneath and reach up to squeeze in the hook parts that snap into place. If you're swapping the diffusers, it'll be even more obvious when it's off.
I had to drive around for a bit without it because my closeout NOS CF unit was missing that cover and I had to fabricate one. I tried my original but it did not fit. The shape was just a little off. I made one out of CF sheet and hand-fitted it. It was a pain, but came out well. I don't even notice the slight mismatch in weave anymore.
Old Mar 1, 2025 | 02:14 PM
  #39
DJS's Avatar
DJS
I’d guess it isn’t designed to come off easily from the exterior, as it’s designed to be installed once, after shipment. Mine too is in storage for 3-4 more weeks.
Old Mar 1, 2025 | 03:38 PM
  #40
lizzardo's Avatar
I meant that my original diffuser is in storage, not my entire car
