Rear wheel (?) rubbing when pulling away slowly
Old Apr 5, 2016 | 01:49 AM
Blkv8s's Avatar
Default Rear wheel (?) rubbing when pulling away slowly
Hi folks!
A few times lately I've noticed a distinct rubbing sound+vibration from the left hand side rear wheel area. It happens when I drive slowly away from my garage into the street, on a shallow left turn arc (on a level road).
My V8S convertible is stock, no mods (yet). Right hand drive of course.
Before I get into proper investigation (to gather evidence for the dealer), has anyone else experienced such a thing?
Can't find anything in the forum...
Thanks in anticipation!
Old Apr 5, 2016 | 08:25 AM
SinF's Avatar
Are you sure this isn't sound that brakes make when disk is slightly rusted from sitting for a while? How often do you drive and how humid where you store your car?
Old Apr 5, 2016 | 08:55 AM
Blkv8s's Avatar
Driven almost every day, not brakes. Tonight I had a thought it could be the diff, when cold or something.
Old Apr 5, 2016 | 09:09 AM
DJS's Avatar
DJS
I had one time where a brake was dragging as I can to a stop - not a nice sound. Getting up to speed and braking hard took care of it.
Old Apr 5, 2016 | 10:47 AM
SinF's Avatar
If it was tire rubbing, you'd see some scuffing on it. In that case, it would be caused by worn/out of alignment suspension component. Unlikely on a car of this age unless you put some serious miles over bad roads.
I think the most likely reason is brakes. It could be caliper starting to stick. It could be parking brake sticking. As someone suggested - do hard braking followed by coasting couple times, see if it resolve the issue. Also engage parking brake while very very slowly rolling (sub 1mph) to do the same for it.
Also, when was the last time you serviced your brakes? If everything original, it is not inconceivable to have early onset of sticking calipers.
Old Apr 6, 2016 | 01:25 AM
Blkv8s's Avatar
Thanks! I'll check those suggestions out and let you know.
Old Apr 6, 2016 | 06:44 AM
Tel's Avatar
Tel
I would be inclined to jack the rear of the car and just check wheel baring play on the lh side (grab the sides if the tire top and bottom-you shouldn't feel any movement) and also spin the wheel by hand and it will be obvious if the brake is binding.
Failing that, get the dealer to check the diff.
Old Apr 6, 2016 | 12:46 PM
F-typical's Avatar
If you've got it on a jack, and you're pushing-pulling on the wheel, it's probably best to grab the wheel at the 9 and 3 positions.
Old May 10, 2016 | 10:26 PM
JigJag's Avatar
Originally Posted by Blkv8s
Hi folks!
A few times lately I've noticed a distinct rubbing sound+vibration from the left hand side rear wheel area. It happens when I drive slowly away from my garage into the street, on a shallow left turn arc (on a level road.
Sounds like you have a bearing on the way out. At least that's what the one I have going out sounds like.
Old May 11, 2016 | 12:15 PM
Awd's Avatar
Awd
Have you checked the wheel lugs/bolts ?
Old May 11, 2016 | 05:09 PM
Unhingd's Avatar
I had something similar. It was a piece of gravel lodged between the disc and dust plate.
Old May 11, 2016 | 10:19 PM
Nati's Avatar
This is reported as a common nuisance with the M4. But the noise is constant once the debris gets lodged if you read the accounts in the bimmer forums.
2010 Kyanite XFR
May 14, 2016 01:02 AM
grahamuk33
Mar 24, 2016 07:36 AM
roberthornsey
Mar 11, 2016 08:38 AM
brinny
Mar 7, 2016 04:45 PM
SD96XJ6L
Mar 7, 2016 10:55 AM
