Reset: Distance to Empty
Old Jun 24, 2018 | 02:51 PM
HalcyonDays's Avatar
Default Reset: Distance to Empty
I had my battery replaced a couple of weeks ago and since then the Distance to Empty does not correspond to the remaining fuel in the vehicle. I know this function is part of the Trip Computer, but I've been unable to Reset by holding in the button on the stalk. Can anyone help? Thanks in advance.
Old Jun 24, 2018 | 03:01 PM
DJS's Avatar
DJS
I believe it’s calculated based on recent fuel economy, but I would expect it wouldn’t take very many miles to figure that out.
Old Jun 24, 2018 | 03:09 PM
I keep the "Distance to Empty" displayed on the bottom of my screen and it always kept a fairly accurate countdown to my next fill up of gas. When I filled the tank it typically read around 220 miles. Now, since the new battery was installed it reads several hundred miles more than it should at all times. Thanks.
Old Jun 24, 2018 | 03:50 PM
Unhingd's Avatar
Reboot all the computers by disconnecting the battery for 15 seconds.
Old Jun 24, 2018 | 09:03 PM
Buckingham's Avatar
When you toggle the eco button, it shows the % fuel left. Is that also wrong?
Old Jun 25, 2018 | 11:25 AM
NavyBlue's Avatar
Just curious, why do you need to know distance to empty?
Just fill up when you're at 1/4 tank, to make sure you're not close to empty, which may wreck havoc to your engine when it's empty...
Old Jun 25, 2018 | 11:31 AM
I agree. I am used to having it in my display. That's the best that I've got.
Old Jun 25, 2018 | 11:36 AM
NavyBlue's Avatar
You're right. I check it on long intra/interstate trips. But since I don't have run-flat tires, I don't drive outside big metro areas now days...
Old Jun 25, 2018 | 02:48 PM
Unhingd's Avatar
I use that miles to empty metric in order to plan out my visit to my favorite gas station.
Old Jun 25, 2018 | 05:54 PM
mominayal's Avatar
That just happened to me today as well and I have had no battery issues/replacement. At all. I was almost down to the red mark and it said 52 miles remaining. Then I put in 3 gallons or so (was in a rush) and it still said 52 gallons. Will check in am when I drive again.
Old Jun 25, 2018 | 06:25 PM
OzXFR's Avatar
I don't know for sure with the F-Type, but on both my XFs the "range to empty" was incredibly pessimistic, it would show "- - -" (ie zero range to empty, you are out of gas!) when there was at least 5 litres and possibly up to 10 litres still in the tank. Many times I went an extra 50 kms or so after the range to empty read "- - -" without a single problem, and the most I could ever squeeze in to the supposedly 70 litre tank was 65 litres. I'm guessing it's yet another one of those modern OTT saaaaaaaaaafety (cue Eric Peters!) things, designed so that JLR cannot possibly be blamed for someone running out of gas due to an optimistic "range to empty" reading.
Old Jun 25, 2018 | 06:30 PM
Unhingd's Avatar
The costly risk is not getting stranded, but burning out the fuel pump when it starts cavitating from fuel starvation.
Old Jun 25, 2018 | 06:31 PM
Mine now has the opposite problem. When I reasonably have 80 miles left, it now reads 180. If I run out of gas, I will blame myself, but being OCD does not help this problem with the Distance To Empty reading.
Old Jun 25, 2018 | 09:11 PM
uncheel's Avatar
If you don't add enough gas, the DTE will not reset. When it happened to me, I rather expected it to adjust at some point before running down to "0." Didn't happen. You can't help but feel a bit nervous, even though you know you should be fine. When you actually fill the tank, it should go back to normal. But, it doesn't sound like the OP's situation is quite that simple. I'd second Unhinged motion to disconnect the battery to force a reboot and heed the warning about the risk to burning out the fuel pump if you did run out (see the manual).
Old Jun 26, 2018 | 09:21 AM
DJS's Avatar
DJS
I don't trust it.
A couple of years ago, I did a 900 mile trip on two tanks of gas, which I wouldn't have thought possible. At the end, the Miles to Empty kept stretching out. When I finished the trip, it said I had 20 mile to empty. I filled up the next day, and it took 1/2 gallon more than the listed capacity of the fuel tank.
Whew.
Old Jun 28, 2018 | 09:16 PM
approx's Avatar
I’ve heard this repeated for years, yet have never heard of a case where this actually happened on a modern vehicle.
Old Jun 28, 2018 | 09:47 PM
Unhingd's Avatar
More likely to happen on a modern positive displacement fuel pump than an old fashioned plunger pump.
Old Jun 29, 2018 | 08:01 AM
Paul_59's Avatar
Banned
Putting in 3 gallons is the clue.
On rare occasions i have put small amount in I have noticed it doesn't update miles to empty,
Whenever i put a significant amount of fuel or fill to capacity it resets miles to empty immediately
Old Jun 29, 2018 | 08:45 AM
This was my experience until I replaced the battery. Now it constantly reads high.
Old Jun 29, 2018 | 09:17 AM
DJS's Avatar
DJS
This is rather interesting, from OzXFR's service manual...
LOW FUEL STRATEGY
The ECM is programmed with a strategy which shuts the engine off
before the fuel tank runs dry. This is to prevent fuel system damage
by air being drawn into the high pressure fuel pump.
A misfire is induced with increasing magnitude when the fuel in the
tank reaches approximately 2.5 liters of useable fuel remaining to
alert the driver to this condition. The engine is shut down when the
fuel in the tank reaches 0.00 liters of useable fuel remaining in the
tank and 4.0 liters of un-useable fuel remaining.
To reset the fuel strategy after engine shutdown, it is required that a
minimum of 4 liters of fuel is added to the fuel tank, when the vehicle
is on level ground.
