Reverse/fog lamp housing bracket
Old Feb 2, 2021 | 01:57 PM
wurldfamuz's Avatar
Default Reverse/fog lamp housing bracket
I finally got a used design pack rear diffuser w lower valance/splitter for my 2016 V6 and apparently its not just plug and play. it looks like my existing clear reverse lamp housing does not bolt right on to the diffuser, the mounting bracket that is molded to the design pack diffuser is different from the standard version.
Can someone tell me the part # for the reverse lamp housing bracket that is compatible and will mount with design pack rear diffuser.
I found these part #''s online T2R17448 & T2R17449 it says they're the reverse lamp L and R brackets, however it doesn't say if it for the standard diffuser or the design pock diffuser, hopefully someone can verify or confrm is these brackets works.
Old Feb 2, 2021 | 04:27 PM
Unhingd's Avatar
l believe you will find that you need different fog lamp assemblies.
Old Feb 2, 2021 | 11:06 PM
wurldfamuz's Avatar
Unhigned - are you saying I'm SOL and I cant just changed the mountng bracket on my current reverse lamp and that I'm gonna have to get another set of reverse lamps?
As i mentioned T2R17448 and T2R17449 description says reverse/fog lamp bracket and says it part of the valance but it doesn't look anything like the bracket that is molded on to the diffuser where the reverse lamp mounts to. It would be great if someone is familiar with the particular part and that I can verify, I called 2 different dealer parts dept and they dont know crap, all they know is how to read the description, I can do that myself.
Old Feb 3, 2021 | 06:24 AM
Unhingd's Avatar
When I converted from the V6 valence to the V8 valence, I had to buy new foglamps. I believe they are the same ones use for the V6 design pack.
Also keep in mind, unfortunately, the drawings in the parts pages are representations, and not necessarily similar to the actual parts.
Flynnstone
Jun 20, 2019 11:25 AM
Marco75
Feb 7, 2015 06:49 AM
AJ34S
Feb 9, 2013 03:09 PM
peppersteak122
Sep 27, 2010 06:32 PM
surphnsnw
Aug 2, 2008 12:37 PM
