In Roll race, for the stcok car, Which RPM should I change?
Old Feb 9, 2020 | 10:22 AM
FullChat's Avatar
IF you have raised the rev limiter, say to 7100 with a VAP tune, then the car will still shift at the old 6700 rev limit. As much of the extra power is high in the rev range, I prefer to shift manually.
Old Feb 9, 2020 | 10:31 AM
Toddiesel's Avatar
400 extra RPMs above redline sounds a little dangerous. How much extra power is the motor putting out between 6700 and 7100? Do you need titanium valve springs to prevent floating at that RPM?
Old Feb 9, 2020 | 12:14 PM
RacerX's Avatar
Banned
This is a 2014 V8 S composite chart over multiple days. The red line is the stock tune with a 6% upper pulley on 0W-20. The blue line is the same plus Racechip on 0W-40. In neither case does a late shift seem helpful.
My belief, which needs more research, is that the car was overheating and/or experiencing blow by with the pulley and pulling timing at high RPM. I went to 0W-40 for the next stage of boost which seems to have helped. The ambient temp was 96F on both days.
The same dyno has several Z06s at ~545 WHP.
RichardPhuket
Feb 2, 2015 01:21 AM
Frizzle
Jan 27, 2015 03:12 AM
RaceDiagnostics
Jan 20, 2015 06:01 AM
