royal purple engine oil
Old Jan 2, 2021 | 09:22 AM
iownme's Avatar
Default royal purple engine oil
can i use royal purple 0-20 engine oil?
Old Jan 2, 2021 | 11:52 AM
EdG's Avatar
EdG
I am assuming you mean in an F Type. If so, engine oil is supposed to meet JLR specifications, STJLR.03.5004. Only a few engine oil brands make a version that meet these specifications and it will be on the label. I have no idea why JLR products needs these specifications or if it makes any difference. I buy oil that meets STJLR.03.5004 since that is what is recommended.
Old Jan 2, 2021 | 02:06 PM
Carbuff2's Avatar
The JLR spec is for a low-viscosity oil that provides rapid initial cold pumping and better fuel economy. Their specification also assures wear protection at high RPM for timing chains and valve components.
The Red Line is Dexos1Gen2 which is a benefit (reduces LSPI or Low Speed Pre Ignition, a common characteristic of GDI engines).
I suspect that Red Line doesn't choose to pay for manufacturers' certifications, but you don't know for sure, do you?
Old Jan 2, 2021 | 04:53 PM
OzXFR's Avatar
If you are willing to spring for that fairly expensive Royal Purple you should instead go for a 0W-20 ILSAC GF-6A oil, the RP you show is only GF-5.
Plenty of info on the web and some on this forum about the newish ILSAC GF-6A (you don't want 6B which is ultra low viscosity 0W-16 meant for hybrid engines).
Judging from the info on the web the problematic timing chains on our AJ133 and AJ126 engines will benefit from using ILSAC GF-6A oil.
Old Jan 3, 2021 | 11:10 AM
iownme's Avatar
I asked as a local dealer has it for $35 for 5l
I'm getting ready for my first oil change, What are the common oils which members here use?.
I imagine most of the research has been done by 6 years of F type forum users already, and oil selection is not my knowledge base, other than wrong oil can be bad!.
I change mine every 3000 miles so im not looking for the high price champagne of oil
MussieRon
Apr 6, 2020 07:15 PM
RA110623
Nov 13, 2019 11:58 AM
powxxl
Apr 11, 2018 05:28 PM
davidladewig
Sep 2, 2017 11:56 AM
jaguny
Oct 3, 2012 06:16 PM
