Rust on Rear Axle Shafts
Old Oct 4, 2024 | 10:50 PM
ftype_rick's Avatar
Default Rust on Rear Axle Shafts
Just looking for others’ opinions on the rust I’m seeing on my rear axle shaft. Problematic or no?
Rust
No rust
Old Oct 5, 2024 | 06:13 AM
TangledThorns's Avatar
Not a mechanical expert but it looks concerning.
Old Oct 5, 2024 | 09:32 AM
Carbuff2's Avatar
Surface rust. Not concerning as long as you treat it.
I would use POR-15 to coat the rust.
If you have an early car, I'd be painting the steel underbody braces while you have the paint can open. In particular, check out the areas behind the wheels...road debris can wear off any coating, even if they are the newer, properly-finished ones.
Some makes have rubber dampeners on the middle of the drive shafts. On those, the axles can actually break if the rust penetrates. The dampeners keep rubbing...eventually they twist apart!
Old Oct 6, 2024 | 08:55 AM
clubairth1's Avatar
Community Influencer
I must say your car is very clean underneath!
asjdhsajhdfj
Mar 1, 2023 02:53 PM
XK Owen
Sep 25, 2022 12:11 PM
asjdhsajhdfj
Jul 25, 2021 10:49 AM
XKR-DAY
Apr 23, 2021 11:11 PM
blackjaguarxk8
Oct 20, 2016 01:52 PM
