Scheduled for a Eurocharged Pulley and Tune
Old Sep 28, 2014 | 09:14 PM
WaltB's Avatar
Thanks Cambo!
Walt
Old Sep 29, 2014 | 12:32 AM
avos's Avatar
Just to complement, I don’t know the newer Ftype ECUs but I guess they work similar as the older 5.0 XKR Denso ones in how they control the engine output. There the ECU is not bleeding of the boost, it controls the torque with the throttle opening. So once you reach a maximum torque, the ECU will not further open the throttle (even though you press the pedal to the metal).
This is also why it was so simple to make ECU tunes without having much prior knowledge on 5.0 XKR cars, the XKR-S model had these torque limiters at a higher level so you could simply locate where these torque limiters where by comparing the maps
The Gearbox also control max torque, so for an optimum tune, ie get the max out of the engine, you would probably also have to tune the TCM.
Old Sep 29, 2014 | 12:54 AM
WaltB's Avatar
Whoa!!!
That is totally different than what others have been saying previously. A bleed valve bleeding off boost vs electronically limiting throttle inputs may have the same end result but are vastly different concepts.
F-typical?
Cambo?
Old Sep 29, 2014 | 01:07 AM
Cambo's Avatar
F-Type has the Bosch ECU, is very different to the earlier cars than run the Denso.
EDIT
If you have a look at the various discussions about tuning the XKR, it is mentioned several times.
Here's one:
https://www.jaguarforums.com/forum/x...38/#post844644
and have a look here too https://www.jaguarforums.com/forum/x...lution-122060/
Old Sep 29, 2014 | 01:49 AM
avos's Avatar
The 5.0 SC cars do not have any mechanism to bleed of boost, there is only a vacuum controlled bypass valve, that’s it, so boost changes as an effect of controlling the TB. Next to that I found this myself by checking all parameters with the IDS so know it by a fact. This way of controlling power is actually already used since the early 4.2 cars.
Old Sep 29, 2014 | 03:25 AM
Cambo's Avatar
Well i'm probably wrong then.
Old Sep 29, 2014 | 12:35 PM
avos's Avatar
No, at most you have been misinformed by some who could have known ;-)
Sorry, I only wanted to compliment the posts already made, by giving some factual info.
Old Sep 29, 2014 | 12:53 PM
  #28
F-typical's Avatar
That sounds like a normal recirculating system - boost is bled into the inlet before the S/C rather than to atmosphere. It should operate on vacuum, even if it isn't electronically controlled, to prevent the S/C providing boost to a shut throttle and blowing the inlet hoses off.
Old Sep 29, 2014 | 03:12 PM
Mulmur's Avatar
So, again I'm a novice concerning tuning issues ... if a smaller pulley is added to boost psi, something would also have to be done with this 'vacuum' system to make use of the added boost. Or looking at it another way, perhaps the existing super charger provides enough boost, however the 'vacuum' system could be adjusted so the engine receives more.
Anyway, interesting stuff ... but confusing to me at times as well.
Lawrence
Old Sep 30, 2014 | 12:30 AM
  #30
avos's Avatar
Its a very simple vacuum operated system, that lowers the SC's power consumption at idle/cruise situations as it equalizes the pressure of the in and outlet.
Old Sep 30, 2014 | 12:37 AM
  #31
avos's Avatar
Lawrence
The vacuum system has nothing to do with the maximum boost you can make, that was my point.
But that is on the 5.0 SC cars with the Denso ECU, I have no knowledge of the Bosch ECUs used. There could be changes in how power is controlled, although I would guess it is still the same.
Old Nov 25, 2014 | 11:35 PM
  #32
donk_316's Avatar
Where are the before and after dyno graphs?
Old Nov 27, 2014 | 08:26 AM
  #33
ldmack3's Avatar
Thanks to everyone for the information.
I'm very interested in the your results of the Eurocharged tune in Houston as that is my plan after I get a little more education on the subject.
Thanks again everyone. Very informative.
MrWhite
19
Jun 14, 2022 07:49 PM
inactualis
Oct 2, 2015 11:13 AM
sdelliott58
Oct 1, 2015 01:46 AM
dan102877
Sep 29, 2015 06:47 PM
