Scraaaaaaaape
Old Dec 14, 2016 | 09:51 AM
stmcknig's Avatar
Default Scraaaaaaaape
So one downside to the new F-Type ownership is getting onto my drive from the road - I always scrape the fender saver strip despite trying different angles, speeds etc. I think it may come down to figuring out how put down some temporary bridging - I've seen anything from bits of wood to what look like recycled tires at varying prices. Anybody tried these and can suggest which ones worked out best ?
Old Dec 14, 2016 | 10:05 AM
Dogbreath!'s Avatar
If you mean the strip under the front bumper, about the only thing that you can do is drive slowly and at an angle so that only 1 tire at a time goes over the area that causes scraping.
I think that part is only $35 and it can easily be replaced when worn to a nub.
Old Dec 14, 2016 | 10:15 AM
Uk2usa's Avatar
Every time we drive out of our Garage it USED to scrape, one day the strip came off completely, I never replaced it. It feels so much better not having to hear it every time.
Old Dec 14, 2016 | 10:17 AM
Unhingd's Avatar
Just live with it. All 3 whiskers cost less than $120 in total and are easy to replace. They will also last a long time with a lot of scraping. If the plastic streamers get too noticeable, just shave them off with a sharp knife.
Old Dec 14, 2016 | 10:41 AM
stmcknig's Avatar
Yes, tried all "angles of attack" but scraaaape always results, especially reversing off the drive. I was pleasantly surprised at the price of the sacrificial part, so I guess when I wear it down, I'll have to decide to replace it and renew the scraping ;-)
Old Dec 14, 2016 | 11:28 AM
Philipintexas's Avatar
I had a similar problem with the street to driveway interface, I had the whole thing cut out and a more gentle slope concreted in.... Not TOO expensive but really is nice.
Old Dec 14, 2016 | 11:51 AM
stmcknig's Avatar
I was looking for a less permanent (and maybe expensive) solution to avoid HOA grief...
Old Dec 14, 2016 | 03:42 PM
Burt Gummer's Avatar
https://www.griotsgarage.com/product...rrivals&page=1
As for the $35 lip piece is its only function to be a warning hit-piece or is it needed for aerodynamics?
Old Dec 14, 2016 | 04:03 PM
stmcknig's Avatar
Hmm I can buy 10 of the warning strips for one bridge. Decisions decisions ;-)
Old Dec 14, 2016 | 05:06 PM
Unhingd's Avatar
The whiskers do serve as air dams (maybe minimally), so keep them in place and let them scrape.
Old Dec 14, 2016 | 09:04 PM
AbyJag's Avatar
I have steep lip and solved the problem by reversing into my driveway. No more scrape except when I forget and..... the car facing forward looks ready to roar out of the garage
Old Dec 14, 2016 | 10:24 PM
bjg625's Avatar
Earlier on Forum recomended to use fine sandpaper to keep bottom edge looking good. I found a fine sanding block that works great. I guess eventually will sand down!
Old Dec 14, 2016 | 11:19 PM
f-type_R_fun's Avatar
I use the Bridjit curb ramp. I liked the 1st 3 pieces enough that I extended it across my 3 car driveway. Very heavy and doesn't move except in heavy rain, and then only a couple feet at most. Amazon has the 3 piece set for $285 shipped with Prime. I used wood in the past and it always floated away.
Old Jan 1, 2017 | 04:42 PM
JohnnyRotten666's Avatar
You have to think of this part as the whiskers on your cat. They enable the feline the ability to know if it can fit into a given space. The one and only time I've experienced this painful noise happened when I fell prey to a rodeside hotdog stand. My lust for hotdogs and need to make a dramatic entrance got the best of me. I about faced my direction of travel and proceeded to enter a gravel parking lot a wee bit hotter then necessary. Neglecting to assess the topography of the undulating parking lot I proceeded to turn my 2017 F Type S into an expensive bulldozer. The noise resonated through my skull like a dentist drill bottoming out on a root canal followed by a spray of 3/8 pea stone showering the hot dog stand twelve feet away......What to do?
Now clearly I had the attention of the hot dog salesman and all the potential customers.
I now felt compelled to a least buy a hot dog so I swallowed my pride ,exited my car and without missing a beat I explained "That's what that part is supposed to do."
Now one positive outcome of making such a dramatic entrance was , like Moses parting the Red Sea I was able to go to the front of the line as the vacationing family of three were so shell shocked by the shower of driveway debris that as I approached they backed up, possibly not knowing and fearing the stability of one crazed driver of a sports car turned excavator...
I bought one hot dog, left a $10.00 tip just in case I scratched the stainless steel side of the hotdog cart,inhaled my purchase in two bites and as stoically as one can, considering the situation, exited.
Now this was a leval of embarrassment that one seldom achieves in life and one I hope never to repeat.....
Please watch your whiskers...
Old Jan 1, 2017 | 04:50 PM
Unhingd's Avatar
Anyone happen to have the 3 part numbers readily available for the whiskers. Mine are starting to look a bit ratty.
Old Jan 1, 2017 | 05:28 PM
OzXFR's Avatar
See here: BUMPER & COMPONENTS - FRONT for 2015 Jaguar F-Type
# 20, 21 & 22.
Old Jan 1, 2017 | 06:56 PM
Madart's Avatar
Get a sheet of checkerplate steel for the bottom of the drive?
Old Jan 1, 2017 | 07:05 PM
Unhingd's Avatar
For me (with 1.5" lower H&R springs), it's not my driveway, but the occasional entrance to parking lots. Love the stance, love the handling, not stressing over replacing $100 in parts every two years. I can keep those whiskers trimmed, but they are now getting to the point that they may not be offering adequate warning.
Old Jan 1, 2017 | 07:59 PM
Madart's Avatar
Rivet a few metal tabs to what's left of the skirt so you get adequate warning?
Old Jan 1, 2017 | 09:05 PM
Unhingd's Avatar
Worth considering.
