Scratched side windows
#41
I had the work done a while back, but noticed in the recent rain that my driver's window was heavily streaked. I cleaned the grit out from between the seal and the glass, and was surprised at how much there was even with the updated seals. I then gave a bit of a polish to the glass with my random orbital polisher using cerium oxide and the special pads it came with. Better, but I'm going to add cleaning that area to my car wash routine.
#45
#47
In my case, since the windows were found to have been scratched, they replaced both windows. They also agreed to redo the tinting after installing the windows.
#48
#49
I have the new style seals but still see signs of grit being trapped. I believe that the problem is inherent in the vehicle design. The angle of the door glass allows dirt to collect and slide down to the seal. When the door opens, the window drops slightly, trapping the dirt.
I've made it part of my cleaning routine to clean that area. I slide something between the glass and see to pick up the dirt. I've also re-polished the driver's side glass, as that's the one that gets used most.
