Smoked rear lenses - comparison
Old Apr 20, 2017 | 03:53 PM
CaptainHam's Avatar
Default Smoked rear lenses - comparison
A little side-by-side of old vs. new rear lenses if anyone is interested - was trying to decide myself if I prefer the new ones or not, but still undecided...
Old Apr 20, 2017 | 04:13 PM
malbec's Avatar
This a similar colour to my Ammonite, may even be identical.
I prefer the darker ones. I gather that they are £300 each, wonder how easy to replace?
Old Apr 20, 2017 | 04:16 PM
CaptainHam's Avatar
Nice close-up, that sells it for me...I prefer darker.
Old Apr 20, 2017 | 05:50 PM
Unhingd's Avatar
It will depend on car color and personal taste.
Old Apr 20, 2017 | 08:42 PM
Nati's Avatar
I certainly prefer the V6 that's in the top car. I still can't get over the f type in a 4 cylinder. Don't care what color the tail lights are.
Old Apr 21, 2017 | 12:10 AM
Greggbhill's Avatar
Top car has all the badges going backwards... :-)
Old Apr 21, 2017 | 12:15 AM
malbec's Avatar
The top image is perverted.
In the second image it's the car which is perverted
Old Apr 21, 2017 | 12:52 AM
FtypeRRR's Avatar
my vote: Smoked!
Old Apr 22, 2017 | 04:28 PM
jaguny's Avatar
Smoked look good.
Old Apr 22, 2017 | 08:31 PM
bjg625's Avatar
Smoked a nice change, but don't know if I would spend much to change, current ones are$400+.
Old Apr 23, 2017 | 09:20 AM
DirtyAir's Avatar
A good tint guy should do it for cheap. Not too much $$$ layout..
Old Apr 23, 2017 | 10:43 AM
CRS 123's Avatar
I think smoking rear lenses would be bad for your lungs...that being said, while I think they look good with some color combos, don't they drastically cut down on light transmission?
CRS
Old Apr 23, 2017 | 07:48 PM
sov211's Avatar
Darkened lenses transmit less light: translation: the cars following you are not getting the message you want them to get with the force intended. Possible result? A good bit of damage to the rear of your beautiful F-Type, and a whiplash injury to you. Not nice, regardless of the appearance of the lens. And as I write this I am in month 5 of whiplash recovery, with a long way to go.
Old Apr 23, 2017 | 08:32 PM
Stohlen's Avatar
Now now... its not that simple. A two way mirror appears to have no light transmission to the other side, but in reality transmits plenty. OEM smoked tail lights operate on the same principal; they are engineered to transmit an adequate amount of light through the lens despite their darker appearance.
Old Apr 24, 2017 | 06:21 PM
sov211's Avatar
This afternoon I followed a car in traffic with darkened tail lamps - darkened to about the same depth as those suggested for the F-Type. When the brake lights of all the cars came on at a stop light, those of the car with the darkened lenses showed at about 50-60 % of the brilliance of all the other tail lamps. So with respect I have to say that I completely disagree with your statement that the brake lights will have "adequate" brilliance with darkened lenses. Brighter brake lights just may avoid some very costly damage.
Jaguar did fit darkened lenses to certain versions of the XJ40 model - and they too transmitted a less brilliant light (possibly the reason they did not continue this practice). I do agree that the darker lenses look good (possibly better than the bright red lenses) ... but....
Old Apr 24, 2017 | 07:36 PM
Unhingd's Avatar
Perhaps the solution for those wanting smoked lenses is to attach a pulsing module to the center LED brake light. I have one of those on my MINI and it wakes people right up. Once I figure out how to remove the interior trim on the hatch I will be installing one on the F-Type as well.
Old Apr 24, 2017 | 07:49 PM
Stohlen's Avatar
You cannot compare someone's tint job to an OEM tail light housing. They are not even remotely the same.
You're just making uneducated assumptions about the design and functionality of Jaguar's smoked tail lamps. Hell, you could increase the light output by using different bulbs with more wattage and have a brighter tail lamp than non-smoked lamps.
Old Apr 24, 2017 | 07:52 PM
Stohlen's Avatar
BMW blacklines have been proven to work even better in the daylight than stock BMW tail lamps because they offer more contrast to defeat glare... They sacrifice no light output.
Old Apr 24, 2017 | 08:14 PM
OzXFR's Avatar
I would like darker tail lights, and I'm a DIY kind of guy, so I was thinking about having a go at putting on some tint film myself. AFAICT the only way to do it properly would be to remove the tail lights and do it on a bench, but even with the factory repair manual I can't figure out how to do this. It also suggests that you need to remove the whole rear clip to get the tail lights out, which seems a bit OTT to me! I reason that the only way to do it properly is to remove the tail lights because the gaps between the lights and the bodywork are pretty damn tight, less than 1 mm in almost all places (which is a good thing!), which would make it very difficult to "cut and fold" the edges of the tint nice and neat and clean with the tail lights in place, well at least beyond my meagre abilities. Or could a pro tint shop do this no sweat?
Old Apr 25, 2017 | 01:07 AM
frank james's Avatar
You can buy pre-cut from lamin x in 3 shades
