Squeaking from rear when going slowly
Old Jan 24, 2015 | 10:21 AM
samteq's Avatar
Default Squeaking from rear when going slowly
I've recently purchased a V6S Convertible which I'm completely loving but when driving slowly around town a quite loud squeak emits from the rear when slowing down (both when braking and when the engine autocratically gears down).
When driving over 20-30mph no squeaking occurs whatsoever.
Has anybody experienced this issue? Going to take it to the dealers but it ruins a day for me so would like to go knowing whats wrong.
Thanks in advanced,
Cheers,
Sam
Old Jan 24, 2015 | 10:22 AM
StealthPilot's Avatar
I think it may be seat rubbing against the panel behind the seat. You need clearance.
Old Jan 24, 2015 | 10:28 AM
samteq's Avatar
I have actually experienced that but this is much louder and noticeable from outside the car.
Old Jan 26, 2015 | 09:02 AM
Lizard's Avatar
Check your tires. Last times I had this problem (both on my m3 and my f-type) it turned out to be a screw stuck inside the tire and the noise comes from the contact to the ground at low speed.
Old Jan 27, 2015 | 09:19 AM
samteq's Avatar
Thanks Lizard, will take a look although I would have though that would cause more of a squeak, squeak, squeak as the wheel spins whereas my sound is more constant for a second or so... Definitely a strange problem!
Thanks again.
Old May 20, 2017 | 10:28 AM
wrs1's Avatar
Default F-type squeak
Thanks in advanced,
Cheers,
Sam
i saw this question above from over a year ago. Just I have just bought a 2014 f-type convertible and have exactly the same problem. I thought was shock absorbers but I get the squeak at low speeds when not going over bumps. Did anyone work this out?
thanks w
Old May 20, 2017 | 12:29 PM
Unhingd's Avatar
thanks w
There was a TSB for a rear suspension problem that was issued early fir the'14-15 cars. It had to do with a clunking sound, but might also result in other noises:
JTB00306v5
Old May 20, 2017 | 01:53 PM
DJS's Avatar
DJS
Presumably, not a brake dragging. Hard braking takes care of that.
Old May 20, 2017 | 03:55 PM
RGPV6S's Avatar
I was just out for a drive in my V6S and started hearing an intermittent squeal from the rear of the car. It sounded just like an old fashioned mechanical brake pad wear sensor kicking in and out.
I thought F-Types had an electrical sensor for this rather than the mechanical type that squeals.
Anyway my car has only 19k on it. Could I need new rear pads already? Usually the fronts go first unless something is wrong with the rear brakes.
BTW: If there is an electrical pad wear sensor how does the car warn you about needing brake pads?
Old May 20, 2017 | 07:16 PM
OzXFR's Avatar
The F-Type has the same ancient pad wear sensor system as the XF.
A single sensor on the right rear inner pad and another single sensor on the left front inner pad.
They are simple "open loop" wires, so that when the sensor wears through the loop closes and the warning is triggered.
On the XF they are meant to trigger when there is around 4 mm of pad thickness remaining, so plenty to spare. But that is only the triggered pad, it's possible that other unmonitored pad(s) could have a lot less, and the OEM pads are notorious for falling to bits around the edges once they get low.
If it's anything like the XF then you will get a warning on the dash "brake pads low" or similar, but it doesn't tell you which sensor has triggered, so you need to manually check.
One or more brake pads worn out at 19k miles, especially the rears, would not be unusual, the OEM pads are very soft (hence the masses of dust) and they wear out very quickly.
On the XF the rears wear much faster than the fronts, due mainly to "anti-dive" built into the braking system such that the rear brakes grab faster and harder than the fronts. I don't know for sure but I suspect the F-Type would have the same system.
So your best bet is to whip all the wheels off and have a good look at the thickness and condition of all the brake pads, well at least "edge on" without the hassle of removing the pads.
Old May 21, 2017 | 08:56 AM
samteq's Avatar
thanks w
Hi
My issue actually turned out to be a problem with the exhust system, can't remember the detail exactly but it was something to do with the values (that make it sound ace) not sealing correctly which is why it only happened at lowish revs. In the end I believe they replaced the whole rear exhust system under warrenty.
Hope this helps,
Sam
Old May 21, 2017 | 10:12 AM
RGPV6S's Avatar
Hi
Hope this helps,
Sam
I just popped the wheels off my car and checked the brake pads on all four corners. The rears were between 6 and 7 mm for inner and outer pads and the fronts were about 8-9mm so probably not the pads. Although I probably will replace them in the fall when the brake flush gets done.
Hope its not the exhaust valves like Sam.
Old May 21, 2017 | 01:19 PM
pbad's Avatar
Hi
Hope this helps,
Sam
I wanted to mention this as well. My symptoms were almost identical to what is being described. It felt speed related but pay attention the RPMs. For me it was a quick squeak/chirp when passing between 1200-1300 RPM. Mostly noticeable at those slow speeds, <30 MPH. It was an issue with the active exhaust valves and the whole muffler assembly or "silencer" as JLR calls it was replaced.
Old May 14, 2019 | 04:27 PM
Luc Lapierre's Avatar
This will be the subject of my next dealer visit, as I've consistently noticed these exact symptoms. Particularly noticeable in parkades.
Right now I'm playing a game.
It's called "common issues bingo".
I seem to be doing fairly well at this game currently.
If I win the game (while still under warranty), then I get to do mods! 😁
Old May 14, 2019 | 11:47 PM
VeeDub's Avatar
I guarantee it is the exhaust valves. You can hear them, especially at engine starts after the valve closes when the RPM drops. I took out the exhaust and tried lubing with some graphite spray lube but no luck. I'll try nickel anti-seize next.
Old May 15, 2019 | 11:47 PM
Anyone ever have any rattling accompanying this as well?
Could just be a loose heat shield. I'm getting it looked at tomorrow at lunch regardless but figured I'd throw a line out here just to see.
Old May 16, 2019 | 08:44 AM
DJS's Avatar
DJS
The electric vacuum pump for active exhaust sounds very much like a buzzing heat shield - it's located behind/inside the left rear wheel. It's most noticeable for me around 1400RPM. Don't know what year you have; the pump was removed in MY16 (17?) and replaced with a vacuum line coming back from the engine.
Old May 16, 2019 | 04:13 PM
Ah, the anecdotal evidence is growing - I did a cold start yesterday and crawled around to see if I could pinpoint the source, this is the exact location I determined. Took a video too in case it decides to behave itself at the dealer.
I have VIN ending in 27692 by the way.
Old May 16, 2019 | 08:04 PM
Unhingd's Avatar
https://youtu.be/nSDFepGjAQU
Your MY16 does not have the vacuum pump. The sound in your video certainly sounds like loose valves on you muffler. Requires replacement of the muffler.
Old Jul 17, 2019 | 10:48 PM
Sorry to resurrect this after so long, but I realized I'd forgotten to ask:
Is there a TSB for this?
