Strange Possible Exhaust noise
Old Jul 16, 2023 | 08:23 AM
FredV6's Avatar
Exclamation Strange Possible Exhaust noise
Anyone have any ideas or experience with this noise?
It’s like a pressure/hydraulic/etc release sound that happens when the car revs fall, either from letting off the throttle and revs come down, or by changing down a gear, and again the revs coming down.
Whilst driving it sounded as if it was coming from the front. However, after listening to it from outside it sounds like it is coming from the exhaust system.
Keen to hear thoughts - it’s in for a service next week, and I’d like to direct the mechanics to the right area, hoping to make things easier their end… and quicker!
Thanks!
Freddie
Old Jul 16, 2023 | 10:55 AM
355rockit's Avatar
Possibly the bypass valve on the exhaust?
Old Jul 16, 2023 | 11:15 PM
2009 XF Vail's Avatar
Banana 🍌 in the tail pipe trick!
Old Jul 16, 2023 | 11:39 PM
Whalesmash's Avatar
Sounds like a squeaky active exhaust valve. I'd guess happening around 1500 rpm?
Old Jul 17, 2023 | 11:39 AM
VroomForTwo's Avatar
It should be more natural, brother. It should flow out, like this - "Look, man, I ain't fallin' for no banana in my tailpipe!"
Old Jul 17, 2023 | 10:06 PM
Simonusa0's Avatar
One (or both) of the exhaust box bypass valves is rattling. Mine has started to do the same exact thing. When you rev it or start it, the valves open and shut depending on speed and load and also startup 'flare' and you will hear the rattle.
Phil m
Aug 25, 2021 10:36 AM
Dan_NL
Apr 25, 2021 10:43 AM
semorex
Jun 12, 2020 08:47 AM
Dan_NL
Nov 21, 2019 04:43 PM
xeqtr_psm
XE ( X760 )
Apr 22, 2019 02:55 PM
