Supercharger alignment pins
Old May 30, 2022 | 11:35 PM
Mpowerr's Avatar
Default Supercharger alignment pins
Hi all,
Does anyone know the PN for the two alignment "pins" that are on the bottom of the supercharger?
Old May 30, 2022 | 11:54 PM
OzXFR's Avatar
I doubt they are listed or sold as a separate part by anyone, odds on to be part of the SC casing at least and even then it might be impossible to buy a new SC casing without buying the whole SC.
Your best bet may be to check wreckers/breakers/dismantlers.
Old May 31, 2022 | 10:29 AM
RGPV6S's Avatar
Originally Posted by Mpowerr
Hi all,
If you have the dimensions you can find replacement dowel pins here:
https://www.mcmaster.com/dowel-pins/
Anything you order here you will get in no more than 1 to 3 days if you are in the US.
Old May 31, 2022 | 12:42 PM
Obi's Avatar
Obi
Following Information obtained from https://classicairheads.com/blog/202...r-replacement/
“The manual calls for “special tool” guide pins to be inserted into the cylinder head to guide the SC down into place on the gasket- these are just 50mmx M8x 1.25 headless bolts. I made some by cutting the heads of some headful ones.”
Old Jun 2, 2022 | 11:29 PM
Mpowerr's Avatar
Yea I needed one to get the dimensions...
Old Jun 2, 2022 | 11:32 PM
Mpowerr's Avatar
Originally Posted by Obi
Following Information obtained from https://classicairheads.com/blog/2020/12/29/off-topic-jaguar-f-type-supercharger-re
moval-coolant-pipe-replacement-and-supercharger-coupler-replacement/
I already have a set of guide pins, that's not what I'm after. I need the dowels that locate the SC on the block.
Old Jun 3, 2022 | 10:41 AM
Obi's Avatar
Obi
Have you removed the supercharger yet?
scottpeterd
Oct 11, 2019 08:36 AM
mshedden
Apr 11, 2018 01:57 PM
jimmie
Jul 19, 2014 11:11 AM
bfsgross
Oct 4, 2011 08:57 AM
