Supercharger removal, "while I'm under there"
Hi all, addressing a coolant smell, not sure where yet, but if the SC ends up coming off what are the main preventive maintenance items (other than replacing/upgrading the lower and upper plastic pipes at the front of the block) while it is off? 2015 R, thanks!
For the coolant system replace ALL the pipes/hose/tubes, there are more at the rear of the block under/behind the SC, plus the coolant pump and the thermostat.
