Symposer Defeat
Old Sep 19, 2022 | 07:11 AM
  #101
hammam almulhe's Avatar
Default Meth setup
Originally Posted by mcphill
Can you post a pic of the top of your SC?
boost reference line is circled in green. It’s super dusty
4 port direct meth injection. Snowperformance stage 2E system with a solenoid + prometh distributer and nozzles. Boost reference is tapped on the sc plenum and lined through the steering column to the controller on the dash
lol. Cons of living in the middle east
Old Oct 29, 2022 | 04:14 PM
  #102
afour's Avatar
I'd like to make the same mod, but what did you do with the wiring harness that went to the vacuum actuator once you removed the symposer?
Did you just leave it unconnected? Does it throw any codes?
Old Oct 30, 2022 | 09:04 AM
  #103
clubairth1's Avatar
Community Influencer
The Symposer sets no codes regardless if it's hooked up or not.
You can disable it anyway you like.
I just unhooked the tube going to the cabin and plugged it. I left everything else in place for now. If and when I pull the blower I will neaten up that area and remove excess the parts.
Old Oct 30, 2022 | 11:22 AM
  #104
lizzardo's Avatar
That's where I'm sitting. I occasionally open the hood and stare at the symposer but always end up leaving it rather than opening the can of worms full removal represents.
Old Oct 31, 2022 | 08:01 AM
  #105
clubairth1's Avatar
Yes it's just so buried at the back of the engine. When I saw a picture of the engine out and all that is involved with the Symposer I just kind of backed off and plugged the tube.
Yea it's worse for you F-Type guys because the hood opens backwards and the Symposer is right there. On my XJ the Symposer is WAY in the back so you got to know where to look to even see it!
If fact I am embarrassed but when all this Symposer stuff started getting talked about I was sure my car did not have it because I had never seen it when working under the hood. I had to look at some pictures to find it.
Old Jan 23, 2023 | 02:55 AM
  #106
MaxD's Avatar
Note this is a LR only part. LR025788
Do you have to remove the S/C to install this part?
Old Jan 23, 2023 | 03:47 AM
  #107
Reaxions's Avatar
I can't speak to the F-Type, but I think it would be extremely hard, if not impossible, to do it on an XF without removing the SC, or at least unbolting the SC and sliding it forward to give some access clearance.
Old Jan 23, 2023 | 04:16 AM
  #108
MaxD's Avatar
It's a curiousity, but I suspect the S/C has to move/be removed for access.
Old Jan 24, 2023 | 08:05 AM
  #109
clubairth1's Avatar
I don't know but the F-Type has the reverse opening hood so the Symposer is all out in the open compared to the cars with front opening hoods. I know on my XJ that getting to the Symposer requires laying on top of the engine and getting back under the cowling stuff.
You can can get to it but it does take a bit of work!
Old Jan 24, 2023 | 09:25 AM
  #110
Reaxions's Avatar
Yep. Reconnecting everything on the back of the engine, even after removing the symposer (so a lot more room to move) after putting the SC back in place was a complete PITA on my XF.
Old Mar 29, 2023 | 04:17 AM
  #111
Borbor's Avatar
For future reference this is the size of high temp silicone plugs that will seal perfectly. The opening is 16mm in diameter.
you will have to cut them as above. You can actually use either part to seal. The plug bit will need to be cut so only 2mm above the rim of the hole and it goes down into the hole or use the top flat bit sits on top of the hole but is compressed and seals the hole anyways when you fit the connection back together .
It makes a big difference to the sound levels inside the car. A lot quieter even under acceleration. Actually too quiet for me
Old Mar 29, 2023 | 06:53 AM
  #112
Sovande's Avatar
Thanks for showing the size you used - I'm going to replace the foam I used with a solid plug. I'm fine with some further reduction in the cabin noise.
I wonder if you could use a plug with a hole in it to limit the sound without killing it all together, for those who still want some pumped in noises? Or possibly just use foam in those instances.
Old Mar 29, 2023 | 08:39 AM
  #113
Reaxions's Avatar
There are a million ways to skin that cat. Just play around with what you like. There are also other ways to get more real engine noise into the cabin or make it quieter besides just the symposer tube.
Old Mar 29, 2023 | 07:58 PM
  #114
lizzardo's Avatar
I'm confident the foam I'm using cuts out effectively 100% and I'm happy with that. The next step will be removal but every time I open the hood and stare at that thing I decide to wait until I'm deep enough in there for something else and close the hood.
Old Mar 29, 2023 | 08:02 PM
  #115
Sovande's Avatar
I just put a silicone plug in as is shown above. It feels like a "cleaner" solution to me since the only foam I had was not able to be fitted as tightly as your pictures show. I won't know til morning if it makes a difference.
Old Mar 30, 2023 | 09:57 AM
  #116
Sovande's Avatar
After replacing the foam I originally rolled up and stuffed in the pipe with a tight fitting silicone plug, the results are pretty dramatic. With the foam I still got engine noise in the cabin through the symposer - it was quieter than without, but still evident. With the plug, the sound is completely blocked and the result is a much quieter cabin and (for me) a nicer driving experience.
Old Mar 30, 2023 | 06:21 PM
  #117
lizzardo's Avatar
The foam I used was dense, closed-cell ensolite I had left over from a car stereo project some years back, and I rolled up a tight plug of it. The next thing I'm doing with the system is removal, but that's low priority. I've got some spiffy parts that have been sitting a long time waiting for installation and they take precedence, although I'm still wary of the lowering springs. I don't want to end up unable to drive on the rod to get to/from home. I'd feel pretty foolish if that happened.
Old Feb 29, 2024 | 06:26 PM
  #118
Zen Beer's Avatar
I am going to 3d print a blocker plate to try out since I am removing mine. Will report back on heat tolerance.
Old Feb 29, 2024 | 07:42 PM
  #119
lizzardo's Avatar
VAP now has one you can buy. I just installed it. Sure, I could have saved a little by fabricating something, but had not found the time to do so over the last few years. I was happy enough with the defeat that the delete just dropped down to the back of the priority list.
Old Mar 1, 2024 | 09:40 AM
  #120
clubairth1's Avatar
Hey your the first one I have heard that installed one.
What do you think? I like the metal construction and the added nipple for measuring boost.
I just have a plastic cap with a clamp on it blocking my Symposer off. Not very pretty for sure!
