There is some offsets questions
Old Aug 20, 2020 | 10:06 PM
bobo_Fan's Avatar
Post There is some offsets questions
I have been thinking about offset for a long time,if i use 255/295 9/10.5 and no short springs to lower the height,what kind of offset is the most perfect。I listened to some suggestions and decided to use ET45 in front and ET26 in back。But There is another problem that bothers me now,Will there be serious mud splashing if I use ET45 on the front wheel?I am not sure if this will happen.....So i am thinking whether to use front ET50 to avoid this situation,Can this be solved?Nice look or conservative et (╥﹏╥)......Custom wheels are expensive, so I want to be cautious....
Old Aug 25, 2020 | 03:02 PM
Unhingd's Avatar
Mud splash is not the issue. Whether you go with a 45 or 55mm offset in front, the front wheels will kick gravel onto the rocker sill just in front of the rear tire and even just above the sill. Clear wrapping the sill and and fender just in front of the rear wheel will protect the paint. The 45mm & 26mm offsets are conservative and will work very nicely..
bobo_Fan
Aug 20, 2020 10:33 PM
daxx
Aug 17, 2009 05:57 PM
bankerkys
Jun 6, 2009 06:42 AM
govatos
Apr 1, 2009 06:04 PM
Knaych
Mar 9, 2009 12:17 AM
