Throttle Tip-In
Hello fellas,
Just wondering if anyone else has noticed the slight delay with the V6S in a daily situation with their car. It might be the way I'm modulating the throttle.
In Normal or Regular mode if I'm driving around and give maybe 25% or 30% of throttle there seems to me about a second or half a second delay before the car actually gets going. Doesn't happen in Dynamic mode however. Maybe the throttle is calibrated this way?
Anyone?
Anyone?
Also,twice now when just starting out when cold I've had the car stay in 1st gear and not want to shift...I've had to stop the car and then go again and it's fine at that point...anyone else?
Hello fellas,
Anyone?
Anyone?
Of course then I depress the throttle further, it kicks down a few more gears, and goes to ludicrous speed and I see plaid.
No,I've noticed something similar too myself...doesn't happen all the time though.
I've had my V8 stick in first several times after I've first backed out of somewhere then turned and driven off. I have always put it down to an accidental knock of the downshift paddle (but perhaps not). I just grab the upshift paddle for a couple of seconds to clear it back to D.
Both times it happen I was just starting out,car wasn't in dynamic mode and I was driving normal just bringing it up to operating temps...
In my first automatic sports car ever, I've learned I can't stand to drive sports cars in automatic mode. I'm not happy letting a car shift for me. Thus, I'm 100% of the time using the paddles and haven't seen the issue described unless I've waited late to shift.
As an aside, I never touch the eco-mode button, haven't disabled the system, and I haven't seen it in action since a couple of weeks after I took delivery last June. The paddles render it inop 100% of the time.
Happened at least three times over the last few months. The only way I've found to restart is fully engage the brake, shifter back into Park, then press the Start button, then back into gear... making me look like an idiot who doesn't know how to drive this really sharp looking car.
It does feel a little laggy when accelerating at about half throttle between 1200 and 2500 rpm or so as well. I think there is little to no boost In that range, and the supercharger mass when not in bypass mode adds a lot of flywheel effect.
My solution is to downshift with the paddles until I have 3,000 rpm them get on it.
Slightly different issue for me... when leaving home in the morning in regular drive mode (sport and dynamic not engaged), and not fully up to normal operating temp, when I come to the first stop sign in my residential neighborhood, and actually come close to a full stop because of cross traffic, rather than my far more customary California stop... If I get back on the gas, at just the wrong moment in relation to the eco-mode just starting to activate, it kills the engine entirely, leaving my slowly rolling into the intersection with no power.
Before driving off I almost always allow temps to get up to speed and I almost never engage in automatic without using the Dynamic setting with paddle shifting 100% of the time. I'll give some of the variations listed here a try over the weekend and see what's what (and report back here).
Good luck fellow idiots!
Hello fellas,
Anyone?
Anyone?
The throttle response on the later build is instantaneous, no lag, no delay, no kick down, no hesitation whatsoever... touch the throttle, the car goes like a bat out of hell in direct correlation to the throttle.
The earlier build has a definite delay in responsiveness to the throttle, in any and all transmission modes. Annoying as heck! makes its performance feel more like most every other car on the road...
I've often wondered if the production delay in the later arriving vehicle has any correlation to the distinctly better performance?
Burnie
Definitely feels like turbo lag. I find myself using S mode on the transmission instead of D a bit more often to counteract this it's a bit annoying when I'm just in the mood to cruise. Definitely too high of a gear/not enough boost situation.
To the question posed in the OP, I've had the opportunity to drive two separate 2015 R Coupes with some regularity since last Thanksgiving... one an early November US delivery, the second delayed several weeks in production and ultimately a late November US delivery.
However, you might be entirely right on the better throttle response on the later cars, mine is an early build even if it's 15.
