Traction Issue SVR
Old May 27, 2023 | 12:30 AM
SVR 575's Avatar
Originally Posted by Robbie68
Hi all, new here and looking for a little advice. Just picked up a 2020 SVR and I’m finding it struggles a bit traction wise in the dry, 1st 2nd gear 70-80 degrees temperature. I’m no stranger to the F Type had a 2014 V8S and 2017 R and I don’t recall the R having traction issues at all, am I missing something? I’m also used to high horsepower cars (2 Hellcats, 2 RedEyes and multiple others) so I don’t think it’s user error. Any thoughts appreciated.
The only time I have any traction issues with my SVR on dry pavement is when the tires are cold. The P Zeros aren't the greatest tire summer and they for sure are harder and more slippery than a Pilot Sport when cold.
Old May 27, 2023 | 06:50 AM
jaguny's Avatar
Car rolling, rolling on tho accelerator quickly, not standing on it in first or second gear I get immediate response followed in a slit second by TC light and power being reduced until traction regained (typical TC intervention) I can live with it, I just remember my R being so much better. Point taken on Pirellis I was thinking this might be the problem, just wanted to see what others were experiencing before Intake it to the dealer to get TC looked or change tyres or lessen traction expectations and drive accordingly.
Sorry for the late reply. I haven't experienced this in my SVR, but I don't recall doing this in wet conditions. I just recently put on the new Continental Summer Performance tires. I have done this in try conditions, but don't recall this happening. Will give it a try over the weekend. We haven't seen rain in awhile here so no wet traction testing in the next week or so at least.
Old May 30, 2023 | 12:53 PM
inmanlanier's Avatar
Originally Posted by Bierry
Couple weeks ago on a dry track, the R understeered, pronounced from corner entry to apex and exacerbated by trail braking however slight, and will still understeer from apex to exit under throttle. It needs to be driven more in a slow, point, then shoot fashion than carry appreciable speed into and through turns.
I have been on the track 4 times and exhibited no such tendencies. I settled on 35 psi front, 37 psi rear cold as the pressures for the track - well balanced. I suggest you bias your tire pressures more to the front next time. I'd start with as much as a 1 or 2 psi bias based on your existing cold pressures (and don't re-adjust hot!). In other words, if you were running 35 psi front, 37 psi rear - start the next time with 36 front 37 rear or perhaps all at 37. Adjust from there (don't worry what the actual pressure is, simply add or subtract 1 psi at a time). You add air to the end of the car that is not gripping to your likes.
COFTR
Jan 25, 2025 05:08 PM
Sdnyc82
May 1, 2022 06:57 PM
ipitythefoo
Mar 17, 2022 05:39 PM
Tally Ho
F-Pace (X761) / C-X17
Jun 11, 2020 03:50 AM
BruceTheQuail
Sep 22, 2016 07:13 PM
