Transmission Bolt Pattern
Old Dec 7, 2016 | 04:00 PM
Unhingd's Avatar
Default Transmission Bolt Pattern
Does anyone know what the bolt pattern is on the back of the engine where the bell housing bolts up on the RWD V8?
Old Dec 8, 2016 | 12:57 AM
Mpowerr's Avatar
Hmm, I wonder what you're up to...
Old Dec 8, 2016 | 01:04 AM
Cambo's Avatar
The same as the V6...
Old Dec 8, 2016 | 06:53 AM
Unhingd's Avatar
I was guessing that, but I don't want to have to pull the tranny to take the measurements. I'm trying to see if the attached bell housing might bolt up to the engine.
The other end of this bolts up to a 700 lb-ft 6 speed sequential Quaife gearbox. Could be a fantastic option for the replacing the MT in the V6 as well. This particular bell housing was designed for a 5.0L Coyote engine.
File Type: pdf
Old Dec 8, 2016 | 03:19 PM
Cambo's Avatar
I'm quite sure that the bellhousing of the AJ133/126 is not the same as the Coyote...
What I can tell you;
The 3.2, 3.5, 4.0 & 4.2 V8 all have the same bellhousing pattern. Which is also the same as the 2.7 Diesel and 3.6 Diesel.
The 5.0 and 3.0 S/C are the same.
The 4.4 Diesel is different to the 3.0 Diesel.
The bellhousing on the 5.0/3.0 is almost a perfect circle
5.0L AJ133S from Range Rover
As is the 3.2/3.5/4.0/4.2/2.7/3.6
AJ41 from Land Rover (4.4 but all identical to 4.2)
But as you can see they are not quite the same...
The Coyote pattern in the Quaife drawing is obviously not a circle, and the starter motor is in a different position...
This is is the 4.4L diesel V8 from the Range Rover (also used in a number of Ford trucks if i'm not mistaken)
4.4L V8 from Range Rover
Looks pretty similar to the older V8's... but also the bolt spacing and the dowels look more like the 5.0/3.0
My understanding is that the 4.4L V8 diesel is also used in some Ford trucks, which might have a manual option available?
Old Jan 10, 2026 | 06:37 AM
madman4's Avatar
Hello,
Did you finally fournd hpthe pattern ?
I'm looking to adapt a 8hp from a XF and need the bellhousing pattern of the diesel V6/V8 to make the adapter.
Old Jan 14, 2026 | 05:31 PM
Zen Beer's Avatar
I have a v6 engine block with bell housing sitting in the back yard. What measurements do you want?
BigJay13
Oct 4, 2024 07:42 AM
chp
General Tech Help
Mar 4, 2024 02:36 PM
luka000
Nov 6, 2018 03:49 AM
Johnny V
Jun 21, 2018 06:51 AM
jahummer
Feb 24, 2015 10:39 PM
