Unsure
Old Apr 23, 2025 | 02:09 PM
AlexMisyuk's Avatar
Default Unsure
So I’m looking at buying this jaguar f type v6 s convertible. It’s a 2016 model with 47,000 miles and it has good maintenance records and everything. But on the window sticker it doesn’t show a limited slip differential which I thought every v6 s model had, should I be concerned or did they maybe just forget to mention it. Other v6 s (non convertibles) I looked at do mention a limited slip differential. I’m just more concerned maybe it isn’t an a real s model even though the money label says it is and it’s being sold as one. (I bought the window sticker from Monroe money labels). I also got the carfax for it and it matches their records and shows up as an s. Any help would be appreciated, Thanks!
Old Apr 23, 2025 | 03:27 PM
DJS's Avatar
DJS
The Monroney labels aren’t 100% accurate. I just looked at the actual window sticker for my V6S, it does say ‘limited slip differential.’
Do you have access to the car? There are a number of things you could look at - pop the hood, and look at the top of the shock towers. If there are harnesses coming out, then the car has adaptive suspension and is an S. Are there valves on the exhaust pipes leading into the muffler (I.e. in front of it)? Is so, it has active exhaust. Don’t think that was an option on the base, but not sure. V6S has the ‘high performance’ brake package, which requires 19” wheels (or larger) to clear the 380mm front brakes.
Old Apr 23, 2025 | 05:31 PM
BruceTheQuail's Avatar
My first XF had an open diff and would get a lot of wheelspin if I gave it the beans when turning, that could be a fun way to test it
Old Apr 23, 2025 | 06:13 PM
AlexMisyuk's Avatar
I just checked the photos I have and the wheel are black with the jaguar logo so I do believe they are the 19 inch rims and the suspension in the hood does have wires coming off of them.
Old Apr 23, 2025 | 07:10 PM
OzXFR's Avatar
Yep, the easiest way to tell from ad photos is the front brakes.
The base has 355 mm front brakes and the S has 380 mm, I can tell the difference from a hundred miles away!
Old Apr 23, 2025 | 07:16 PM
Evoex's Avatar
link the photos
Teddy000
Jan 15, 2024 08:00 PM
Beretta9
Nov 7, 2023 09:31 AM
brian18332
Jan 10, 2018 04:31 PM
Pringleblue
Jun 22, 2014 05:24 PM
