V6 Crank pulley map
Old 02-21-2018, 04:01 AM
Cherry_560sel's Avatar
Originally Posted by Cambo
What's stopping you from driving it (sensibly) on the stock tune with the pulley fitted?
Answer: nothing
From what I have heard...anything over 2,500 RPM will throw a code..but meh...who cares, the S/C will just bleed of the extra boost....so yeah.
Old 02-21-2018, 06:02 AM
Unhingd's Avatar
Received 4,637 Likes on 3,359 Posts
[QUOTE=Cherry_560sel;1845976]
Originally Posted by Unhingd
I usually average 12-16 mpg when I go for a drive. Does that answer your question? Never upshift under 4000 RPM, and throttle input is limited by traction only. I’ve already blown up 3 (crappy) clutches. Yes... I drive it hard. (Not as hard as tracking it, though)
holy crap .... three!!!!
what was the downtime and labor cost to replace?
mine os slipping on hard launches every once in a while.
@Stuart...thanks for explaining the logic behind your decision on your crank pulley size. Stopped me from making an impulse buy...lol.
The clutch on these cars is a known issue. Read the following thread: https://www.jaguarforums.com/forum/f...h+satisfaction
Check first with your dealer. if the car has less than 15k miles, they might cover it under warranty as were my first two replacements. I had to pay for the 3rd replacement. The dealer's original labor quote was $2600 and I negotiated them down to $1900. I only had them do it since they were already half way through the project to determine if Jag would cover the cost. The dealer also let me provide the parts which can be had online for 40% off (total of $1350). Next time I'll use my performance shop and custom made parts. Before this, I never went through a clutch in less than 40k miles, and can't remember ever replacing a clutch on any of my racecars.
Old 02-21-2018, 06:16 AM
Unhingd's Avatar
Originally Posted by v8mgbgt
Thanks for all the info.
I’m not using a handheld programmer.
I have all the soft and hardware to remap vehicles.
Was looking to fit my own crank pulley and download a compatable map so I could drive it to the tuners to get it setup specifically for my engine.
Once a map is downloaded to an ECU it can be copied. I believe the VIN locking is for dedicated handhelds. Unless I’m wrong about that.
What you are proposing will indeed work. You will still need to get the OEM tune file onto a computer to be modified. Most tuning programs can take one file and compare it to another, so a tuner could more easily determine what maps/tables need to be modified in the OEM file. This assumes that the modified tune you get from someone else is in a file format that is compatible with your tuning software. Of course, this doesn't consider the ethical aspects of ripping off the intellectual property of another tuner that put the massive effort of identifying the correct maps/tables of the hundreds or thousands in the file to modify to develop a safe and effective tune.
ndabunka (02-22-2018)
Old 02-21-2018, 01:52 PM
We have a dealer in the UK who can sell you our crank pulley tuning file, all OBDII flashed. David Appleby Engineering in Banbury.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old 02-21-2018, 10:33 PM
v8mgbgt's Avatar
Thanks Stuart
Have already spoken to Appleby about getting the car tuned there.
Had not concidered buying a tuning file of them to match the crank pulley.
Will give them another call.
Old 02-21-2018, 11:14 PM
Thanks Stuart
Sounds good. They would be able to OBD flash it for you with our Kess V2.
You can spec the file with a few options - eco stop/start deactivation, pops & crackles, set up for 200 cell cats etc.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old 02-21-2018, 11:20 PM
Thanks Stuart
BTW - your handle.... I don't know if you go on the MG Experience site, but my brother is detailing his Ford 200 Straight Six swap into an MGB! Pretty cool swap, it's period and being aluminum with aluminum heads it's actually lighter than the 4 pot.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
  #28
Old 02-23-2018, 11:49 AM
v8mgbgt's Avatar
Hi Stewart
I had an MGB Sebring with 4.6 V8 and all Jaguar IRS suspension.
Have sold it now and put money into XKR GT3
Old 02-23-2018, 05:23 PM
Hi Stewart
Both very cool. My brother put an IRS in, not sure where it's from though. He was originally going to go forced induction but after finding a good aftermarket aluminum head he realized he'd be at 300ft/lbs at almost no RPMs and had more than enough power!
Do you have any pics of the XKR?
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
  #30
Old 02-25-2018, 08:25 PM
v8mgbgt's Avatar
Hi STUART
Got 300ftlb out of the 4.6 rover which wasn’t quite enough once I had the IRS suspension sorted. Way too much for old leaf spring setup.
Will see if I can find your brothers on the net.
My XK is running LS9 engine and transaxle. Might be on the road one day.
  #31
Old 02-26-2018, 12:07 PM
Hi STUART
http://www.mgexp.com/phorum/read.php...69#msg-3603769
He could definitely get more. He actually has a Hoslet turbo setup to go on it, but he originally went that route because the Aluminum crossflow heads weren't available than and he needed it to make the power. With the crossflow head guys are easily getting 300ft/lbs which for a newbie on the track I think is plenty.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
  #32
Old 12-22-2019, 04:52 PM
Ftypeman's Avatar
Originally Posted by Stuart@VelocityAP
Another consideration, and I'm saying this for general info because I know you already know this - anything beyond the pulley size we fit you will actually start to run into issues with a very touchy throttle, and secondly will start to overspeed the supercharger - for example the pulley setup you have, as we know is starting to run out of the efficiency range of the compressor. Really, an upper + lower is going to make some more mid range and not much more top end.
It would be similar fitting a slightly larger crank pulley. Really to go more than 450BHP would need a larger charger.
how much would you get out of it with a larger charger? A question I have difficulty to find is how much can you actually can get out of this engine? Can you get 600hp for example or more? And if so what would it take? I understand that people are getting like 1000hp out of V6 supras because of the demand, etc. But is it technically possible to get more than 450-480hp out of the S or 400 version? Thanks!
  #33
Old 12-22-2019, 05:09 PM
Mahjik's Avatar
https://www.jaguarforums.com/forum/f...6/#post2152777
STP Tuning - Jaguar F-Type Tuning Masters
B-rad
04-10-2018 07:12 PM
hofusa
12-02-2017 09:56 PM
SanjKP
06-25-2017 11:08 PM
xjrwithproblems
08-05-2010 02:42 PM
Namor
08-18-2009 06:26 PM
Quick Reply: V6 Crank pulley map
