VAP V6 upper SC pulley
Old May 16, 2022 | 11:35 PM
jahummer's Avatar
Originally Posted by Stuart@VelocityAP
Hi Dennis,
The point that the gentleman in the video is making that is valid is - there are less problems with slippage if you upsize the crank pulley versus downsizing the supercharger pulley. As a general rule that's not wrong. It's particularly important on the JLR supercharged engines because the tensioner design doesn't allow much wrap on the upper pulley anyway. (It's also one of the reasons the belt needs to fit snug.) However, our Griptec pulley doesn't have any problems with slippage as we've verified through datalogging. This would not be the case with a standard steel or aluminum pulley without the coating.
I realize this isn't the X150 forum but have you the ability to offer one for the M112 fitted to the 2007-2009 XKRs?
Old May 17, 2022 | 11:21 AM
Stuart@VelocityAP's Avatar
Not at this time, unfortunately.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Feb 25, 2024 | 01:43 PM
boo radley's Avatar
Default High quality, 94 octane
Originally Posted by datriani
Hey Stuart
Sounds like there’s some confusion as to what changed regarding the details around any benefit for a smaller SC pulley on the V6 pre/post your recent GripTec advancement.
As I understand it, prior to GripTec technology a smaller pulley on the SC had some slippage at the higher RPM which negates any real benefit. But with the GripTec advancement, you’ve eliminated that and we’re able to see an additional 2 psi of boost.
The increase in RPM on the SC is slightly above the manufacturer’s specs but it sounds like the manufacturer understated it’s true tolerance… similar to our engine’s redline (6500 vs. 7000 with your ECU/TCU tune). So no issue with the increase but as with all mods, it’s also based on how hard you drive and push the limits of your car.
And you’re also saying (in other posts) that with the increase in boost, it’s critical to have high quality fuel to prevent knocking but otherwise it’s a safe and a way to get an additional 20 HP on top of the crank pulley/ECU tune.
You will only need "high octane" fuel if you plan on racing.Any modern car has an ECU that pervents knocking. High octane for street use is an oil company money grab. That os unless you have points a condenser and a carb...
ramsftype-s
Jan 31, 2022 11:42 AM
J444G
Jun 13, 2021 07:17 PM
VPinGA
Apr 9, 2020 05:43 PM
Cherry_560sel
Aug 14, 2017 10:09 PM
stmcknig
Jun 21, 2017 12:40 PM
