VelocityAP Jaguar F-Type ECU Tuning, V6, V6S, V8S, V8R
Old Sep 23, 2024 | 12:23 PM
  #1361
Tuning@VelocityAP's Avatar
Originally Posted by bfrank1972
Thanks for the answer! I would have thought the cats were the most restrictive thing in the exhaust but I guess the mufflers are pretty restrictive too. Problem is, it goes from restrictive super quiet to essentially a muffler bypass lol. That plus the VAP cats make for a good time, but it can cause problems with the noise restrictions. What would you recommend?
I would recommend reaching out to your sale department over phone, they can help cater to your desired exhaust note.
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
Old Mar 22, 2025 | 09:55 AM
  #1362
cujet's Avatar
I purchased the Stage 3 Velocity tune, lower and upper pulleys and trans tune for my 2017 V6s. Velocity was good enough to include a Stage 1 tune for the interim. Health problems got in the way of tuning my car and Stage 1 is where it sits now. I love the way it performs. Would be nice if it pulled a bit stronger in the mid range.
My question is this: The lower pulley is a black simple pulley, and I've read that some of them were failure prone. How do I know if mine (it's new and uninstalled) is one of the 'bad batch' or if it's no problem?
Any suggestions as to where to find the proper top pulley puller?
Old Mar 22, 2025 | 10:56 AM
  #1363
Stuart@VelocityAP's Avatar
Sponsor
You could reach out to us directly and provide us with your order information, picture of your pulley and we can look at the date it was supplied. We had a batch of pulleys with a materials issue from our supplier. We subsequently beefed up the design of the pulley to 'engineer around' any materials inconsistencies. We will be able to provide you with more accurate information than the general public can here.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Apr 2, 2025 | 01:15 PM
  #1364
Sponsor
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Apr 2, 2025 | 07:40 PM
  #1365
lizzardo's Avatar
Thanks for the video and the explanation, Stuart. It all makes sense to me and I find the interaction of the throttle and bypass valves to be really interesting.
One of the key points to remember is that the "gas pedal" is just an input to the computer (Drive by Wire, or DBW). I did some work years ago on an open source tuning project and I think the throttle input was labeled in the tuning tables as "Requested Torque." How the system delivers on that request varies, and the systems I worked on were turbo and NA, so there was no such bypass valve. I had an earlier tune that was a bit sensitive in low to mid RPM and partial throttle, but Chris sent me an updated tune to smooth that out. I'm not sure when he updated the tables, but I got the updated tune five years ago.
Old Apr 2, 2025 | 08:03 PM
  #1366
Sponsor
Believe they are generally labelled as 'Torque Driver Demand' or something like that.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Apr 3, 2025 | 05:17 PM
  #1367
pjr300's Avatar
I have a 2014 f type, 5.0 495 HP. Does anyone know which of these three 5.0 options I would select when downloading the factory map?
Old Apr 3, 2025 | 05:28 PM
  #1368
DJS's Avatar
DJS
Does it scroll down? Yours is technically a V8S, assuming it’s a US car.
Old Apr 3, 2025 | 05:31 PM
  #1369
Sponsor
The one that says 364KW, which should scroll the text to show MED17.8.31, although any of them that say MED 17.8.31 should work.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Apr 3, 2025 | 05:32 PM
  #1370
pjr300's Avatar
Thanks!
Old May 1, 2025 | 10:00 PM
  #1371
pjr300's Avatar
Is there a method that the new Map file actually loaded to the vehicle?
Old Jun 11, 2025 | 06:55 AM
  #1372
pjr300's Avatar
I continue to experience issues since install <60 days ago, and just now the OBDC light is on. Are there current instructions to reverse the tune back to OEM? I'd like to isolate whether the light is due to a bad sensor, the tune, or something else.
Old Jun 11, 2025 | 09:01 AM
  #1373
The original file is already in the device. Perform the same process to select the modified, just this time select “Original”.
__________________
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
Old Jun 12, 2025 | 08:20 PM
  #1374
pjr300's Avatar
The OBDC error disappeared immediately upon returning to the OEM tune, and the performance has improved with the OEM tune. Makes no sense to me; could there be a issue with the Map file sent to me?
Old Jun 12, 2025 | 09:42 PM
  #1375
The OBDC error disappeared immediately upon returning to the OEM tune, and the performance has improved with the OEM tune. Makes no sense to me; could there be an issue with the Map file sent to me?
I do not see any emails about a concern like such, is there a reason you have not reached out to us directly?
__________________
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
Old Jun 12, 2025 | 09:56 PM
  #1376
pjr300's Avatar
I did.... Wasn't getting a response.
Old Jun 12, 2025 | 11:42 PM
  #1377
Our tuning support is waiting on your email.
tuning@velocityap.com
__________________
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
Old Dec 30, 2025 | 09:32 PM
  #1378
Slip_Angle's Avatar
That's because there's an overboost limiter allowance for 10 seconds, so for 10 seconds the power can overshoot the max spec setting.
Can you share more details about this overboost? That really makes sense because if you look at the 0-60, 5-60, 30-50 and 50-70 times in Car & Driver comparing the P450 to the R, it's really close on the roll but only to a certain point and then falls off.
Old Jan 6, 2026 | 11:35 AM
  #1379
Nothing extra to note about it..
It will allow 10 seconds of overboost, and then timeout preventing overboost for 20 seconds. Once that 20 seconds has lapsed, it'll again allow overboost for a max period of 10 seconds and repeat.
__________________
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
Old May 11, 2026 | 06:52 AM
  #1380
J444G's Avatar
Hello @Tuning@VelocityAP
Please can throttle cutoff when simultaneously braking be disabled?
I am located in EU, should I buy directly from VAP or elsewhere?
Thanks!
