Warning lights on hot days in sun.
Looking for expert advice on my 2016 V6S convertible that I have owned for 2 years. I only drive car on nice days when I can get some good backroad time with top down, otherwise in my garage. On 3 different occasions, after being in sun with top up on a pretty hot day, ~85 F or above, car above 100 when I get in, I've had some odd warning lights. Twice I've had an airbag warning, the air bag light as if there is a problem with it. Yesterday after being in the sun, I had an odd issue where the top would not go up or down, after working fine at the start of the drive. Without pressing roof switch, the car would make a ding sound and say roof latched, but then as I would drive I would get a quick warning that I was going too fast put the top down even though I was not trying to put the top down. I tried to get see my alerts in the menu section but couldn't. The warnings happened so fast, I could not get to warning menu as the menus would reset with each new warning.
All issues have resolved after sitting overnight again in my garage. I doubt the dealer can do anything about it since everything is better now (still under warranty). I assumed there was a slightly suspect air bag connection/relay that was heat sensitive since I've had that issue twice. But with the roof, it could mean a wider issue. However, I have no idea what it could be since I assume the air bag electronics are separate from roof mechanisms.
These issues do not happen every time in the hot sun.
Any thoughts?
Any thoughts?
Do you keep the car on a battery maintainer in the garage? If not, I'd suspect the battery as the first point of investigation, at least to eliminate it - these cars are very sensitive ot low battery voltages which can give rise to weird "faults".
Michaell
Jan 26, 2015 08:53 AM
