Welcome lights problem 2021. X152 f-type
Old Apr 12, 2025 | 04:28 PM
Piotrx's Avatar
Default Welcome lights problem 2021. X152 f-type
Hi,Hello to all forum members. Can anyone solve my problem? When I open the car, both front lights come on, but the left one goes out faster. I don't know what the problem is. If I turn on the daytime running lights or low beam, everything lights up correctly. This is link with the problemhttps://youtu.be/qh5mkNfuThI?si=WQtRodWiJ89f2dGc When lowbeam are on everything works properly
Old Apr 12, 2025 | 10:06 PM
JagCode3's Avatar
Your left headlight appears to be the culprit. There is no DRL LED strip on that side (like on the right side).
https://www.jaguarforums.com/forum/f...-256355/page2/
I see you posted on the UK forum also - lots of discussion there about it but usually affects 2018-2020 pre-facelift models.
https://www.ftypeforums.co.uk/viewtopic.php?f=27&t=6411
Look for a used unit on eB (with a guarantee that the DRL LED is working) because these are expensive for a brand new replacement.
Old Apr 12, 2025 | 10:30 PM
JagCode3's Avatar
Actually you are still under warranty so get the dealer to replace it with a new one.
Old Apr 19, 2025 | 01:53 AM
Piotrx's Avatar
thank you for your answer. see photo below. When I turn on low beam everything works fine.The left lamp has a shorter presentation time. the problem is only when opening the Jaguar. maybe it's a matter of settings or coding?
Estam
Aug 15, 2023 07:21 AM
gmakel
General Tech Help
Mar 12, 2018 11:13 AM
ftypel
Jun 7, 2014 03:29 PM
