What are the Key Differences Between
Old Feb 5, 2021 | 12:28 PM
Jonathan Ivgi's Avatar
Default What are the Key Differences Between
The R SvR and Project 7?
would it be a good idea to.. take those “differences”
and Upgrade my Type R?
Old Feb 5, 2021 | 03:07 PM
Hell Cat's Avatar
If you're tuned, you already make more power than the stock svr and 7, so that really leaves asthetics.
Is it worth trying to convince people you bought more car than you actually did? That one's up to you, but it would be an expensive deception. An svr fixed wing runs ~$7k, for example. The titanium exhausts run ~8K per side, iirc. Something something law of diminishing marginal utility.
But hey, you do you.
Old Feb 6, 2021 | 02:49 AM
thought there was more that just aesthetics? nothing more internally?
Old Feb 7, 2021 | 07:09 PM
Unhingd's Avatar
Mechanically, the P7 is identical to the ‘15 R (RWD) except that it is tuned to 575 hp.
The SVR is similar to the ‘16-‘20 R except for the 575 tune, forged rear suspension parts and titanium exhaust making for a slightly lighter car. The ‘21 R has the tune and suspension of the previous SVR. I don’t know if the titanium exhaust was carried over as well.
Old Feb 7, 2021 | 09:01 PM
worth getting the suspension parts?
Old Feb 7, 2021 | 10:04 PM
BruceTheQuail's Avatar
I can remember reviews suggesting the the SVR felt a lot lighter at the front end than the AWD R, but I cant remember which review it was. Apparently the parts are the same, so it may be something else. This review might interest you https://www.motortrend.com/cars/jagu...hter-pointier/
Old Feb 8, 2021 | 12:59 AM
u102768's Avatar
There are a few other differences:
Special Vehicle Operations engineers have developed a bespoke transmission
calibration for the F-TYPE Project 7, with revised shift points and characteristics.
F-TYPE Project 7 benefits from bespoke, Special Vehicle Operations-engineered
front suspension knuckles which give increased negative camber, revised top
mounts and new front/rear anti-roll bars.
The front and rear spring and damper units are height adjustable, and both spring rates
and damper internals have been tailored specifically to F-TYPE Project 7.
The Adaptive Dynamics controlling software has been precisely
re-calibrated to suit F-TYPE Project 7, the Dynamic Stability Control system
also having a unique state of tune.
Old Feb 9, 2021 | 07:44 AM
So I’m already running more power than the SVR. Just wondering if transposing p7 and SVR parts would make the R lighter?
Old Feb 9, 2021 | 12:56 PM
zach05855's Avatar
The P7 has a bit more
Body materials redesigned and re-engineered using Carbon/Glass fibre
 New Front upper splitter – Carbon Fibre
 New Lower splitter – molded Black plastic (for higher durability)
 New Side Skirts – Carbon Fibre
 Rear Diffuser – Carbon Fibre
 Adjustable Rear Wing – Carbon Fibre
 Hood vents / Side Vent Louvers / Mirror Caps – Carbon Fibre
 Full Rear deck material – RTM Glass Fibre
Aero Performance Figures
 Front: -0.05 coefficient of lift
 Rear: -0.005 coefficient of lift
 Drag 0.43Cd
 Standard F-TYPE convertible (roof down, spoiler up) total lift: +0.078,
 PROJECT 7: Total lift: -0.060 (downforce) = Improvement of 0.138 (177%)
 121lb (55kg) of downforce at 300 km/h
Full Specification – Enhancements above a standard F-TYPE R:
EXTERIOR:
 All New Front Bumper with Splitter
o New Side Grille Mesh
o New Center Grille & Surround
 New Carbon Fibre Air Diffuser
 New Carbon Fibre Side Sills
 Carbon Fibre Side Vents
 New Rear Body Upper and Trunk Lid with Aero Haunch
 New Infill Panel with Aero haunch and roll hoop cover
 New Trunk Lip
 New Adjustable Rear Wing
 Carbon Fibre Wing Mirrors
 Carbon Fibre Hood Vents
 New Detachable Convertible Top (usable to a limited top speed)
 Unique exhaust tip finish
 New Graphics in White or Grey depending on vehicle exterior color
o Front Stripe
o Number Roundels (optional)
Chassis & Suspension modifications
 Adjustable Performance Tuned Suspension
 Reduced Ride Height
 Bespoke Performance Knuckles
 Performance Springs
 Performance Top Mount
 Modified XKR-S GT Front Damper
 Modified XKR-S GT Rear Damper
 Performance Front Anti-Roll Bar
 Performance Rear Anti-Roll Bar
 New Continental ContiForceContact™ Tire*
o Front: 255/35 ZR 20 (97Y) ContiForceContact
o Rear: 295/30 ZR 20 (101Y) ContiForceContact
 Carbon Ceramic Matrix (CCM) Brakes
 20” Storm Cast Wheel in solid Black Finish
 New matte black Tail Pipes
 New specific tuning for:
o ABS brakes
o Power Steering
o Torque Vectoring by Braking (TVbB)
o Adaptive Dynamics
o Electronic Active Differential
*Note: Despite the fact that the ContiForceContact tire is a road-legal tire, it is optimized for usage on the race track. Due to the very sporty design with reduced tread depth and a compound based on dry handling, Continental recommends driving carefully and attentively, especially on wet surfaces. Vehicle stability is reduced in wet conditions, increasing the risk of an accident (e.g., aquaplaning).
Powertrain and Performance Targets (subject to final engineering verification and testing)
 575hp Engine (+25hp Upgrade)
 Rear Wheel Drive
 ZF 8HP70 transmission
 80 kg (175 lb) Weight Reduction (Target Value)
 TSS Stop/Start Deletion
 Engine Cover Deletion
 Nürburgring Lap time 7.35 (Target Value)
 0-60mph = 3.8 (Target Value)
 Top Speed= 300 km/h (186mph)
Old Feb 9, 2021 | 02:27 PM
eeeeek's Avatar
I'm betting it had forged wheels. That would account for a lighter feel.
Old Feb 10, 2021 | 08:35 AM
Unhingd's Avatar
If you don’t already have CCB brakes you could lighten the load far more cost effectively with forged wheels and 2pc. rotors than with a swap of suspension parts.
DGL
Oct 3, 2020 01:56 PM
Tally Ho
F-Pace (X761) / C-X17
Jun 11, 2020 03:50 AM
a8silver
Oct 15, 2017 12:32 PM
BruceTheQuail
Sep 22, 2016 07:13 PM
santacruzmg
Mar 25, 2016 11:02 AM
