Wheel data thread (posts must include weights!)
Old Jan 4, 2022 | 08:43 AM
jcb-memphis's Avatar
Default Wheel data thread (posts must include weights!)
PLEASE add data to thread. OEM AND aftermarket.
This thread is meant to help find data on F-Type wheels. It is not meant to address tires - just wheels, but users are welcome to note the tires that are commonly used on these wheels and such.
Weight is a mandatory feature as it is often (almost always) missing in action on all websites including Jaguar sites.
Lug nut information is also strongly encouraged - saying OEM is fine but if a wheel needs a different type/shape of lug nut that information can be of help to others in a huge way.
Here is my proposed format:
Wheel Name(s):
Picture(s):
OEM?: Yes/No
If not OEM, manufacturer:
Realistic time to get a new one and source: (dealer, days, wheel is custom made and months, etc.)
Cost retail (not your special price because you know someone, what a normal person would pay without a group buy, etc.)
Sponsors of this forum that carry this wheel: (e.g. AlloyWheelsDirect)
Specs: diameter/width/offset/center bore.
Weight(s):
(note to all, JLR wheels have to pass the same tests the rest of the Land Rover wheels do - a 45mph curb hit and not be damaged or damage the suspension per Harry M. of Harry's Garage - see the P450 review at 22:30...so while they weigh a bit...they may be far tougher than any other option and getting home without worries is 'fun' too)
OEM TPMS compatible: (yes/no)
Piece count: monoblock/two piece/three piece
If multipiece are spare parts available? (yes/no/na)
If multipiece can it be rebuild locally or does it have to go back to the manufacturer or a specialist (yes/no/na)
Material: aluminum/magneisum/carbon fiber/titanium, etc.
Manufacturing method(s): cast, forged, flow formed
Center bore: (OEM or if not, what is done to address the issue)
Center cap size (OEM or other, if other the specs if known)
Compatible with OEM carbon brake rotors? (yes/no)
Lug Nuts (OEM, other special needs, standard, problematic):
Manufacturer warranty data:
Warranty transferable: (yes/no)
Manufacturer contact data for support: (for OEM just say OEM) Website data is good here with email and phone numbers if possible: e.g. the JLR dealer or many parts sites for oem wheels
Part numbers data if known:
Misc. Comments by the post author: Known to bend easily or be fragile in general (crack/fail), hard to clean, poor paint quality, easy to mar lug holes due to being very tight fit, company hard to reach, other issues only an owner would know about.
Opinion by posting person on ease of cleaning (A=easy, B=average, C=tough)
I'll start off with 2 and hopefully others will chime in with more data. The goal is to please not put posts up that are opinions or comments on the wheels. One post for one wheel model (multiple sizes are allows so long as you provide the data for the sizes as able).
Hopefully this can become a resource for the group over time. I have certainly wanted this and seen others asking over threads for these data.
jeff
Old Jan 4, 2022 | 09:09 AM
Default Jaguar ROTOR 20" (also called aero)
Wheel Name(s): Rotor (have also seen "Aero", type 5062, and combinations of these terms)
Picture(s):
Black style:
Grey style:
OEM?: Yes
If not OEM, manufacturer: na
Realistic time to get a new one and source: (dealer, days, wheel is custom made and months, etc.): Local dealer can get these in theory overnight if not in stock. Sponsor can air freight them and has them in stock (AlloyWheelsDirect).
Cost retail (not your special price because you know someone, what a normal person would pay without a group buy, etc.): Black wheels at AlloyWheelsDirect on day of post $4675 for four, grey variant is $6472 for four. These wheels are about 1100 to 1400 each and can be bought one at a time.
Sponsors of this forum that carry this wheel: AlloyWheelsDirect (see the box to the right)
Front:
9Jx20 ET55
Rear: 10.5Jx20 ET38
Centerbore is OEM 63.4. Wheels are hubcentric.
Weight(s):
Front: 16kg (35.27lbs)
Rear: 18.2kg (40.12lbs)
OEM TPMS compatible: (yes/no) yes
If multipiece are spare parts available? (yes/no/na) na
Material: aluminum (T6), carbon plates are attached to the wheel for looks but have not structural role
Manufacturing method(s): forged
Center bore: OEM
Center cap size: OEM
Compatible with OEM carbon brake rotors? no
Lug Nuts (OEM, other special needs, standard, problematic): OEM
Manufacturer warranty data: OEM (if new with car, new car, if bought later 2 years)
Warranty is transferable: Yes.
Manufacturer contact data for support: JLR dealer, sponsor website, others
Black front:
T2R3292
Black rear: T2R3293
Gray front: T2R11271
Gray rear: T2R11272
Misc. Comments by the post author: Unique to Jaguar brand. Very strong. Still for sale at the dealer. No web history of issues or problems. Simple design should age well and has so far given it has been for sale since 2014 or so and remains in demand. OEM tires used with these on the F-type 255/35/20f, 295/30/20r.
Opinion by posting person on ease of cleaning (A=easy, B=average, C=tough): A
Old Jan 4, 2022 | 09:25 AM
Default Jaguar Orbit 19"
Wheel Name(s): Orbit
Picture(s):
Silver:
Black with machining:
OEM?: Yes
Cost retail (not your special price because you know someone, what a normal person would pay without a group buy, etc.): AlloyWheelsDirect on day of post $2514.19 for four in silver. The black with machining are $2816.14 for four. These can be purchased at the dealer in single wheels. They are still available afaik.
Front:
8.5Jx19 ET50
Rear: 9.5Jx19 ET27
Weight(s):
Front: 15.16kg (33.4lbs)
Rear: 17.2kg (37.9lbs)
If multipiece can it be rebuild locally or does it have to go back to the manufacturer or a specialist (yes/no/na): na
Material: aluminum
Center bore: OEM
All silver front:
T2R9704
All sliver rear: T2R9705
Black with machining front: T2R9706
Black with machining rear: T2R9706
Misc. Comments by the post author: Unique to Jaguar brand but an interpretation of a pretty traditional design so while unique not really that unique, but a really well done variation of a classic. Very strong. Still for sale at the dealer. No web history of issues or problems. Classic design should age well. OEM tires used with these on the F-type 245/40/19f, 275/35/19r. Not that common on F-types.
Opinion by posting person on ease of cleaning (A=easy, B=average, C=tough): B
Old Jan 5, 2022 | 06:51 PM
BritCars's Avatar
Great intel.
Where does the info about having to survive a 45mph curb collision without incurring any damage come from?
I know for a fact the 20inch Selena wheels (popular on the XF) bend easily at half that speed hitting a pothole much less obtrusive than a curb. I have bent several over the years...
Many other jag wheels are similarly made of a seemingly soft alloy that bends easily too. Seems less of an issue on the F Type forum (far less driven in the winter on pot holed roads) but a very common issue with XF, XJ etc
terrific that you are collecting this data. Particularly on weight as it's so hard to find!
Old Jan 6, 2022 | 03:11 AM
MajorTom's Avatar
Originally Posted by BritCars
Great intel.
Harry Metcalfe mentioned it in one of his videos. He was baffled by how heavy his Project 7 wheels where, talked to people he knows within JLR and was told that the F-Type wheels and suspension was so heavy because it's made to the same spec as Land Rovers which apparently implies that kind of impact resilience.
As you say it doesn't seem to be the same with XF wheels. During my eight years of XF ownership I also read countless cases of people that buckled their XF wheels on potholes.
Old Jan 12, 2022 | 02:21 AM
takeapieandrun's Avatar
Appreciate the information, I knew my Orbits were rocks but never actually knew the weight. I'm imagining how much good a set of forged wheels, getting rid of the spacers, and two-piece rotors could do, but my wallet doesn't like it.
Unhingd
Mar 26, 2026 12:46 AM
djyankees31
Mar 30, 2021 06:15 PM
RoadMaster2
Jun 4, 2018 04:38 PM
Peter Ucinski
May 23, 2018 07:29 PM
1avguy
Nov 6, 2014 08:26 AM
