Why there are two tire pressure values on display?
Old Feb 6, 2026 | 10:45 AM
J444G's Avatar
Default Why there are two tire pressure values on display?
On dash there are two values for each tire. One "normal" and one in brackets. Values are/can be different, and also one value seems to change to "--" when driving.
I cannot find what does this mean, anybody knows?
Old Feb 6, 2026 | 11:20 AM
Tracy Rominger's Avatar
On is the set point or what the optimum pressure is the other is real time and changes with driving time and such
Old Feb 7, 2026 | 06:49 AM
scm's Avatar
scm
Yes, the one in brackets is what the car thinks you should set the pressure at (37 psi in mine). When you're driving it knows you can't be doing the pressures so maybe not worth displaying the value, only the actual pressures in real time.
Old Feb 7, 2026 | 07:11 AM
Carbuff2's Avatar
At least, you guys get some information. Our '14 just sets an alert!
Old Feb 7, 2026 | 07:49 AM
J444G's Avatar
Thanks a lot guys. From UI point, no so intuitive! I have found that F-paces have an info description on the display for it.
Old Feb 7, 2026 | 08:53 AM
scm's Avatar
scm
Intuitive from an intelligence point, though - from the handbook I knew the recommended pressures were 37 psi so not hard to deduce what the bracketed numbers were telling me.
NYCJAG2006
Aug 11, 2025 09:51 PM
Stuart S
Jan 2, 2015 08:33 PM
philbou
Dec 25, 2012 04:15 PM
