Will this wheel and tire set up fit?
Old Jun 23, 2018 | 01:31 PM
Dibi's Avatar
Default Will this wheel and tire set up fit?
Hey Gang. I'm new to this forum, just picked up a 2014 f-type v8 S. I'm in the process of doing a few modifications, one of which is wheels and tires. I have a set of Rohana wheels that I like but just need some conformation on fitment. The offsets seem close enough for my application but just wanted some input from others on this forum.
BTW im lowered on H&R springs
The wheel Size is
20X9 35mm offset for front with mp4s 255/30
20x11 30mm offset for rear with Mp4s 295/30
If I try and go to 265 Front and 305 rear I can change offsets to 45mm front 35mm rear
Please let me know if either of these will work
Thank you for your time.
Old Jun 23, 2018 | 03:03 PM
Unhingd's Avatar
The rear will work well. Right tire diameter and will extend the rear face out 14mm beyond the OEM face.
The front is a bit more iffy. The tire diameter is a bit short (30 vs 35 aspect ratio) but that won’t be a issue on a RWD car. The offset , however, will push the face out 20mm. Lot’s of folks running with 17mm spacers in front with no issue. I don’t think anyone has tried 20mm spacers, but it may be ok.
Old Jun 23, 2018 | 04:06 PM
Dibi's Avatar
Thank you.
So so just to confirm the 305 tires with the 35 mm offset is good on the rears.
What at would be a more ideal offset for the front for 255 or 265 wide tires?
I dont know know why but doing rim/tire/offset calculations always confuses me.
Old Jun 23, 2018 | 04:26 PM
Unhingd's Avatar
Originally Posted by Dibi
Thank you.
In your first post, you cited a 30 mm offset for the rear wheels. That would not accommodate 305‘s. However, if they are indeed 35 mm offset, you won’t have any trouble at all fitting 305’s.
On the front, a 38 mm offset is guaranteed to work with the 255’s and a 43 mm offset is guaranteed to work with the 265’s.
Old Jun 23, 2018 | 07:49 PM
Dibi's Avatar
Thank you again.
tampamark
Nov 18, 2016 04:08 PM
DayOff
Oct 14, 2016 04:45 PM
SNG Barratt USA
VENDOR 'For Sale' Classifieds
Sep 9, 2015 09:54 PM
Azcat
Nov 4, 2013 07:19 PM
Ingo
Oct 22, 2013 11:01 PM
