2002 XJR Transmission oil
Old Jan 9, 2013 | 05:46 PM
captmal777's Avatar
Default 2002 XJR Transmission oil
I have just spent the last couple of hours looking up what I thought would be a simple question...WHAt TRANSMISSION OIL FOR XJR WITH 722.6 TRANS..... I am now SOO confussed with all the different opinions,(but in all fairness that does not take much) seems like folks jump from the 722 to ZF without taking a breath??...It appears if I read all posts right the best oil to use Is
(1) Shell ATF 3403/M115 OR (2) MOBIL LT 71141 OR (3) CASTROL IMPORT MULTI VEHICLE 5HP30 OR 5HP24....CAN ANYONE CONFIRM WITHOUT DOUBT THE CORRECT ONE.....THANK YOU IN ADVANCE FOR ANY HELP ALSO THE CORRECT AMOUNT WITH OUT CONVERTER....CM
Old Jan 9, 2013 | 08:49 PM
Vector's Avatar
Here is a list of approved fluids from Merc: MB 236.14 - Automatic transmission fluids (ATF, Specification 236.14) - Mercedes-Benz Specifications for Operating Fluids
I used Shell ATF 134 in mine. Got it at Ryder Fleet Products for about $5 per quart.
Vector
way2far
Aug 31, 2022 09:26 AM
Rlover
Mar 30, 2016 10:04 PM
XJsc-guy
Sep 25, 2015 11:09 AM
Dicque
Sep 19, 2015 12:53 PM
AL NZ
Sep 4, 2015 08:39 PM
