2003 xj8 A/C not very cold.
Old Aug 1, 2017 | 05:25 PM
MacyMolly's Avatar
Default 2003 xj8 A/C not very cold.
A/C not very cold. I'm average, mechanically. Is this something I can do by adding freon or do I need to take it in and have pressures, flushing and leak checks? Any advice is greatly appreciated.
Old Aug 1, 2017 | 07:05 PM
The 'correct' approach is flush, check for leaks and, if there are none, refill with the correct weight of refrigerant and PAG oil.
However, you say it's 'not very cold' which suggests it could just be low on refrigerant so you may get away with adding refrigerant. It's a gamble because the AC is a complex system and there's a lot can go wrong to cause insufficient cooling.
Here's the relevant extract from the workshop manual:
Climate Control System - Diagnosis & Testing.pdf
See the Insufficient cooling section.
Old Aug 11, 2017 | 03:39 PM
PDMiller's Avatar
I bought a pressure tester off Ebay and some canisters of top up gas. I was probably lucky but the pressure in the system was low and a can of gas restored it to where it should be and it's been fine for a year now. Debatable weather it's worth it or not because the gas is expensive and a lot of places do a set price top up. I think our cars take a lot of gas to bring them up to the mark.
