2010 XF Rear Brake Replacement
Old May 19, 2022 | 04:31 PM
dericjohns87's Avatar
Default 2010 XF Rear Brake Replacement
Hello all, thank you for reading this and I appreciate any advice on how to handle my current dilemma.
My uncle has a 2010 XF 5.0 N/A that I am replacing the pads on. I have quite a bit of experience with cars (roughly 15 years) in general but I am super stumped right now on how to proceed. I replaced all the pads (discs are in great shape, car has 23k). I used a piston retractor to push the piston into the caliper, the passenger side went fine but the driver side is being extremely stubborn. I am a little confused as to why the piston on driver side (left hand drive) rear is not seating all the way back into the caliper. I have done some looking around online and some research and see conflicting information on how the electric e-brake is disabled. If anyone has any advice I would greatly appreciate it. The closest dealer won't touch the car because it is over 10 years old and the only shop that said they would handle the work wanted $2,800 to change it out and while I completely understand and respect mechanics, almost $3,000 for a pad replacement just seems absolutely insane.
Thank you,
Deric.
Old May 19, 2022 | 05:35 PM
Welcome to the forums Deric,
I agree that $3000 is excessive. Clearly quoted to discourage you because they didn't want the job. Did you PUSH the pistons back or WIND them back? Rotation is essential as they are pressed into the caliper body.
Follow this link
https://www.jaguarforums.com/forum/x...-x350-x358-28/ to the X250 forum for help, advice and information. You can also use the US Southern Midwest Region forum by following this link https://www.jaguarforums.com/forum/us-southern-midwest-67/ to find other members in your region.
Please read the
guidance for new members ( https://www.jaguarforums.com/forum/n...ned-up-241802/ ) which answers many of the most frequent questions about getting started.
Enjoy the forums.
Old May 19, 2022 | 08:22 PM
Got the issue sorted, I had double checked that the e-brake was off before I started and I guess my uncle re-engaged it. Thank you.
Old May 20, 2022 | 02:16 AM
Good to hear it was a simple solution and not a seized piston.
Please post future TECHNICAL questions about this vehicle in X250 model forum
https://www.jaguarforums.com/forum/xf-xfr-x250-44/
Old May 21, 2022 | 07:57 AM
guy's Avatar
guy
too many cooks…
James59
XF (X260)
Oct 27, 2019 01:14 PM
redshift
Dec 19, 2016 11:25 AM
xkrmd
Feb 1, 2016 07:30 AM
Kaeghl
Apr 14, 2015 06:45 PM
JaguarXJR02
Aug 17, 2011 08:55 PM
