Could I please have the TOPix summary fro my I-Pace VIN SADHA2B17L1F86607 ? Many thanks in advance
Very little showing on TOPIx for your vehicle:
This could be because Israel vehicle data is not being made available or the because the vehicles are built under contract by Magna Steyr AG & Co in Gratz, Austria.
..... I did the intro..even posted several items in the X300 forums I would really appreciate if you could look at.. SAJEA03V331M74437
Mark,
Too early a Model Year for the full Minor Details to be generally available through TOPIx. Jaguar have not transferred all data for older vehicles and only the Features are available for your STR.
A Jaguar Dealer would be able to access the full specification through the Direct Dealer Warranty System which is NOT publicly available.
Thank you GGG, sorry I wasn't clear enough, it's not actually mine yet and once it's in my hands I will introduce myself properly. This one was written off and trying to find out as much info as I can. The rear was damaged, but I viewed it today and it looked OK to me.
Hello from Costa Rica, new member and first time poster.
I recently bought a second hand 2015 Jaguar XF 2.0GTDI in Lunar Grey Metallic and Charcoal interior with only 14,000 miles on it.
Google directed me here for VIN decoding, so would really appreciate if @GGG was so kind as to help me get the detailed build sheet with minor specifications and service history, if available.
Wow that was fast, thanks a lot!
Already went ahead and did my proper introduction as suggested!
Is the service history or any other useful info available for my VIN!
.....Is the service history or any other useful info available for my VIN? .....
NO - only UK and mainland Europe OSH (Online Service History) is openly available - see post #48 for an example. For other places service history is still in paper format or only accessible by Jaguar Dealers.
Hello again!
Tomorrow I replace the Fuel pump, fuel filter, pump relay and fuse on my 2000 S-Type 4.0 to hopefully drive her for the first time. I tried resetting the Inertia Valve first but no luck or fuel pressure to the injector rail (yes, there is fuel in the tank). Spins freely but absolutely no fuel pump sound/pressure. I bought all the parts to do the R/R, after it starts with starter fluid but dies after igniting it completely.
But noticed this thread and I'd love a "Build Sheet." Unfortunately the nearest Jag Dealer is either over an hour away across the border in Canada, or 90 miles South by Seattle.
VIN #SAJDA01D9YGL67483 if someone would be so kind?
Thanks All!!!
Reason: Punctuation
..... noticed this thread and I'd love a "Build Sheet." Unfortunately the nearest Jag Dealer is either over an hour away across the border in Canada, or 90 miles South by Seattle.
Thanks All!!!
Too early a Model Year for the full Minor Details to be generally available through TOPIx. Jaguar have not transferred all data for older vehicles and only the Features are available for your S-Type.
Graham:
I thank you for the attempt! It was worth a shot for me to not have to drive to the nearest dealer in Canada or Seattle.
On a good note.....I changed the fuel pump, relay, fuse and she started!!! Couldn't get the lug nuts off to remove the wheel for accessing the fuel filter, they are all too damn tight!
I'm going to replace all the OEM discolored 2-piece lug nuts with some black 1-piece lugs. I'll replace the fuel filter then.....
Again GGG thanks for the try!
Does this print out have details of the locking wheel nut key??? I believe it was mentioned somewhere that it does!!! N I have lost mine with a puncture and barratts say they can’t order new one and I need to drill them out!!!! ☹️
