Air con conversion
Old Oct 18, 2009 | 09:14 AM
test point's Avatar
You didn't identify the MY of your car but I assume you are referring to the R12 type connectors that went out in the early '90s. The newer R134 type connectors are larger.
Converters are available but are usually only used when changing out the system charge to R134. If your friend still has R12 gas in stock he should have the necessary connectors.
You should not mix the gases.
Old Oct 18, 2009 | 05:56 PM
"You can't get better than a Kwik Fit Fitter" especially when he's had a couple on Sunday lunchtime!!
scooternva
29
Mar 25, 2025 12:45 PM
Mugatu
22
Jun 23, 2020 01:50 PM
tonyforman
Sep 10, 2015 07:23 PM
Nasayr
Sep 9, 2015 06:20 AM
sklimii
Sep 5, 2015 06:04 AM
