Air Con Electrics Fault
Old Jul 24, 2022 | 08:23 AM
Patch66's Avatar
Default Air Con Electrics Fault
Hello everyone,
I am in the UK but the same issue could have been experienced with right or left hand drive . I have an XF 2.2 diesel ( 2013/14 ) plate. I had 3 electrical faults in the same week which leads me to think there is a master fuse for these compnents. The three problems relate to the following:
  • Air con ( Climate control ) All electrics still work on the console but there is no longer any air coming through the vents.
  • Screen wash : The wipers still work ok but there is no water coming through the water jets - full bottle of water.
  • ECO: The electrics on the console and instrument panel say that ECO is either on or off when I activate the button, but the engine doesnt should down when ECO is on.
This all suggests to me that there is a "master fuse" that may have gone that controls all of these, I dont know, just guessing. I have checked each of the 5amp fuse for the aircon and all fuses look ok, no breakages.
Any help with this problem is very much appreciated.
Kind regards.
Patrick
Old Jul 25, 2022 | 06:03 AM
Welcome back to the forums Patrick,
Another Jaguar and another set of electrical problems! I hope the intervening years have been trouble free.
Have you first eliminated the number one cause of weird electrical/electronic issues with modern Jaguars - a partially discharged or failing battery? The XF has a considerably more complex module and network design than your previous XJ8 and is very sensitive to battery condition.
As you have already checked fuses, the next logical step in troubleshooting would be a diagnostics session. However, I suspect you may not have access to Jaguar SDD or equivalent. A 'hard reset' could possibly help but does lose all learned adaptions such as window travel, radio presets and fuel trims.
Old Aug 1, 2022 | 07:01 AM
Bill400's Avatar
Hello Patrick, Welcome!
The common thread is likely the OBDII.
Suspect a defective washer pump, unrelated to the other two.
But start with the A/C fan, as that is easy to evaluate. Check power to fan, if missing, check resistor in the air duct nearby the fan.
Download the service and electrical manuals found at the top of the page for self-help.
Keep us posted.
Old Aug 1, 2022 | 08:52 AM
Patch66's Avatar
Hi Bill,
Thanks for your reply and suggestion. I was looking to download the manuals you referred to, where exactly are they please.
Thanks again.
Patrick
Old Aug 2, 2022 | 08:17 AM
Bill400's Avatar
Originally Posted by Patch66
Hi Bill,
Thanks again.
Patrick
Go to: Jaguar Forums File Download Area, Folder Index - Jaguar Forums - Jaguar Enthusiasts Forum
Look under your model but check other models too.
Translator did an excellent job; no doubt invested much time. But still treasure to be found in adjacent areas,
Old Aug 2, 2022 | 08:31 AM
Patch66's Avatar
Thats great , thanks again.
Patrick
George05
Mar 29, 2022 12:03 AM
briciola
Feb 21, 2022 08:42 PM
JonWat
Jun 3, 2021 07:56 PM
RePalm
Mar 9, 2018 01:26 AM
anita Day
Jul 29, 2012 08:15 PM
