Bearing replacement XK8
Old Apr 14, 2026 | 12:24 PM
multiplecats's Avatar
Default Bearing replacement XK8
Hi all,
Just getting ready to press in a new front wheel bearing for my XK8. I've heard about the trick of cooling the bearing in a freezer for a few hours to assist, but is there any advantage in adding a thin coating of oil or Moly grease to the inside of the Hub beforehand? Kind of thinking any lubricant might be pushed out under extreme pressure.
Thanks, Andrew.
Old Apr 15, 2026 | 10:13 AM
clubairth1's Avatar
Community Influencer
Heating and/or cooling is fine. I never use lube on any press fit parts unless the instructions say to. Clean and aligned properly. It's suppose to fit tight.
Old Apr 15, 2026 | 10:50 AM
RoverJoe's Avatar
I always clean and lightly lube the surfaces on press fit bearings like that, if it actually helps, I don't know, but it makes me feel better about it.
The grease can't hurt, it's mostly going to get squeezed out anyway. The interference fit of the metal will still hold it. I just don't want any chance for it to bind or get cocked at an angle while pressing and cause damage.
Aleather
Jul 27, 2021 08:15 AM
liquidreality
Sep 9, 2014 08:08 PM
scardini1
Feb 20, 2014 10:09 AM
2meke
Jul 2, 2013 03:36 PM
xenophobe
Mar 25, 2013 08:12 AM
