Brake problems x308
Old Nov 28, 2022 | 08:43 AM
jrb53's Avatar
Default Brake problems x308
Hi all 2002 x308 I am stumped on my brake issues. I had to replace a steel brake line that started leaking no problems there bled brakes several times no air in lines brake pedal is good now the problem is abs light comes on in heavy traffic. If I pump the pedal light goes out so I think it either master cylinder or booster before I start throwing money at it any ideas would be appreciated. I re soldered the abs board checked for vacuum leaks hose to booster is good thanks jrb53
350XJS
Nov 28, 2023 02:46 AM
Nardoswiss
Oct 31, 2022 05:46 PM
David Hawthorne
Feb 23, 2022 02:01 AM
Tina Botterill
Jul 14, 2019 05:05 AM
maamilton
Feb 25, 2013 10:14 PM
