Camshaft Position Sensor Disassembly ? ?
Old Oct 25, 2019 | 06:54 PM
HapPann's Avatar
Default Camshaft Position Sensor Disassembly ? ?
Hi, I have an 1996 XJS 2+2, and I recently removed the Camshaft Position Sensor to rebuild it. It looks to me that the lower shaft have to be removed from the gear teeth section. My problem is the lower shaft which has the gear teeth on it, is held together by a compression pin. Any suggestion on removing this gear shaft from the unit ? ? Am I correct, is it a compressed pin ? ? Disregard the compression pin concern, found a video on web showing similar rebuild on a 1987 Buick Grand National cam sensor.l Which I know how to link the video I would
Privateer98
Jun 29, 2022 06:15 PM
Kopi
Feb 24, 2022 04:31 AM
Vee
Jan 27, 2018 05:51 PM
steventoon
Nov 13, 2013 02:11 PM
Idrivejags
Dec 1, 2008 07:26 PM
