Can someone verify a 2.5L and a 3.0L Head Gasket???
Old Dec 27, 2009 | 01:12 AM
03jaguardown's Avatar
Exclamation Can someone verify a 2.5L and a 3.0L Head Gasket???
I asked a mechanic(so called) whats the diff. from a 2.5 and a 3.0 he said the pistons are larger and the heads are little different.. but he said the head gaskets are the same, what???? if the pistons are larger on the 3.0L would the gaskets be larger also?? and what about the valves it should be larger as well right??
Old Dec 27, 2009 | 07:37 AM
Thermo's Avatar
Veteran: Navy
Jaguardown, based on an 03 2.5L and 3.0L engine, this is some of the data that I was able to find:
Cylinders (bore and stroke):
2.5L engine - 81.6mm x 79.5mm
3.0L engine - 89.0mm x 79.5mm
exhaust valves:
2.5L engine - 26.15 - 25.85mm
3.0L engine - 30.15 - 29.85mm
Intake valves:
2.5L engine - 30.15 - 29.85mm
3.0L engine - 35.15 - 34.85mm
So, looking at these numbers, I would be betting that the head gaskets between the two motors are not compatable. With different bore diameters, that alone tells me that the two are not capable of being interchanged.
If you need more info, let me know.
Old Dec 27, 2009 | 11:08 AM
exhaust valves:
Intake valves:
well that makes sense!, i kinda new it but im no jag. expert so i thought i would ask....thanks
duecedriver
Dec 25, 2015 11:47 AM
jaguarguy13
XJ40 ( XJ81 )
Nov 8, 2015 08:16 AM
vicom
Sep 17, 2015 03:32 AM
bavareze
Sep 11, 2015 01:49 AM
1964Daimler
Sep 9, 2015 11:20 AM
