Charging system advice
I have a 1967 mk2 340 that has an alternator system just like an e type. The car is positive ground with a Lucas alternator (11AC), remote regulator (4TR), alternator relay (6RA) relay ignition relay (3AW) for the ignition light.
The ammeter reads neutral at idle and a slight charge with increased speed and the voltage at terminal B does increase with increased RPM to 14-15 volts.
Should it keep running with a battery cable disconnected (engine dies out until it is reconnected)?
Will it do any harm if the 3AW ignition light relay is disconnected (missing)?
I am considering replacement with solid state 3AW (38706X). Does anyone have any experience with this relay?
Thanks,
Ron
Thanks,
Ron
Hello Ron . . . and greetings from a Jaguar enthusiast down under. I just noted that your questions haven't provoked a response . . . and I fear that's because they really are far too specific to have attracted the attention you need in this General Tech forum.
I suggest you jump over to the model specific forum for your Mk2/340 and repeat your questions there. Our tech gurus who have highly specific knowledge you seek will thereby see it and be able to respond.
Best wishes,
Ken
Best wishes,
Ken
Charlene n John
Sep 28, 2015 06:01 AM
