Cleaning charge coolers
Old May 12, 2020 | 10:42 AM
James Hunt's Avatar
Default Cleaning charge coolers
Whilst my car is in bits I am cleaning as many things as I can. I have removed the two charge coolers (as photo below). What is the best way to clean these?
Old May 12, 2020 | 12:42 PM
jazzyjags's Avatar
I soaked mine in degreaser for 2 days and rinsed them a few times. I also sprayed a good foaming engine cleaner inside of each manifold port to clean the heat exchanger. You cant really get to scrub it inside, but if you run pressurized water (just from the "jet" setting on your typical garden hose nozzle) it makes a difference when rinsing.
Old May 12, 2020 | 12:43 PM
jazzyjags's Avatar
Make sure you remove that sensor first!
Old May 13, 2020 | 04:07 AM
James Hunt's Avatar
Thanks. I'll give that a go
petemohr
May 25, 2019 03:05 AM
Dukejag
Mar 26, 2019 01:58 PM
brinny
Apr 23, 2018 05:14 PM
XJ8JR
Sep 29, 2014 07:51 PM
