Hello, I am thinking about buying 2002 Jaguar X-Type. The car looks great, low mileage, everything looks good, but there is one thing that concerns me. The middle of the steering wheel is "popped" I don't know what could cause it. Can it be a sign that airbags have been deployed? It doesn't show any engine light code though.
Can it be just a minor issue, maybe just push it back? Does any of you know? I attached two pictures where you can see it.
Maybe plug in the reader and see if it is seeing the airbag there.
A generic reader won't see the airbags, just the powertrain, so you will need something like the NT610 or similar to read the abs, srs and chassis codes.
It's very easy to turn the light off and hide stuff that has happened.
Definate cause for suspicion though.
Whats the owner say about it?
Hello, thank both of you for replying. I went to see the car yesterday. All the lights went on when the ignition switch to on position. When started they switched off. The current owner told me that he bought this car a little bit over a year ago, drove it on temporary plates for a month and then not used it too much because he had a different car. Like I said the car looks really good, no signs of collision whatsoever, an interior is nice and clean. Also, there was a slight crack on the dashboard on the passenger side but it was barely visible and it has probably nothing to do with it.
I know, it's a gamble for sure haha Like I said the car looks really nice and other than this I didn't see any problem with the car. I just wonder, could this cause the car not passing the inspection?
