Extended Warrantees
Old Oct 10, 2012 | 01:02 AM
heima's Avatar
Default Extended Warrantees
Because what better way to prevent death, than to buy life insurance....
Just how much am I going to get reamed at the dealer for an extended warrantee? I've got a 2003 s-type with 67k. Am I still even eligible for an extended warranty?
Old Oct 10, 2012 | 11:26 AM
Fraser Mitchell's Avatar
YOu will probably be able to get some sort of warranty, but with a 9 year old car it may be expensive. However the fairly low mileage is on your side, as most warranties will not cover beyond 100k miles. Almost all these warranties are insurance policies, so when you clim, they go through it with a fine toothcomb to see if they can exclude anything. Other thing is cost; you have to balance paying out and keeping the money in the bank.
Old Nov 19, 2012 | 08:02 AM
baldeagle15's Avatar
One thing to bear in mind about aftermarket extended warrantys is that they usually exclude leaking seals. That is one of the most likely failures (water pump, A/C compressor, transmission, etc.) and it won't be covered!
MonacoDK
Jan 22, 2022 12:33 PM
Presence
Mar 13, 2016 02:21 PM
Johnken
Sep 30, 2015 02:46 PM
reb1999
Sep 26, 2015 08:41 AM
vacolorito
Sep 25, 2015 09:29 AM
